Steering problem
/ Steering problem #1
tazewell
I have a new holland t5040. The steering isn't working properly. When first started it doesn't steer as it should and at times will not steer at all. It gives a steering code and warning to stop at this point. After warming up for a few minutes the steering gets better and stops giving the code, but still not what it should be.
/ Steering problem #2
I am just going to throw ouit some general ideas since I know nothing about your tractor. Does it have a seperate PS resivour. Is it full. Does it have a PS filter. Does it have a seperate power steering pump. Could a suction hose be colapsing when the oil is cold. You need to give a better discription of the problem Does it steer hard, does the steering wheel just spin, does it make noise.
Bill
/ Steering problem #3
You might want to find out what the code means. BTW if no one on the site knows what code you are looking at, they can not help you with problem.
/ Steering problem
The steering is hydrostatic with on reservoir but a separate pump.
/ Steering problem
It has one reservoir but I think it does have a separate pump. It is very hard to steer and will work intermittently. The hydraulic fluid is full and the code shows a steering wheel but does not have a number. It sounds when the steering does not work.
DEERE 544K GP Bucket (A68134)
DEERE 544K GP...
PALLET OF MISC MOTORS AND PARTS (A67714)
PALLET OF MISC...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
2009 TRAIL KING PNEUMATIC TRAILER (A67714)
2009 TRAIL KING...
