stick welding with fixed lens
   / stick welding with fixed lens #1
Tractorrr
TN
kubota bx 2370-1
I'm starting to learn stick welding and am interested in learning with a fixed lens welding helmet. Is there a trick or technique on to how to start an arc with a fixed lens? Once the hood is down I can't see much and I'm just guessing where to start. Do you just simply get the electrode close to the work, flip your hood down and then begin?
I also have a metalman auto darkening hood but I found my eyes were straining with it and I've also read it's just better to learn with a fixed lens in general anyways.
   / stick welding with fixed lens #2
With your rod next to the area you want to start and wearing welding gloves, take the hand that's not holding the stinger and hold the rod a couple of inches up the rod. This gives you better control. When it lights, remove your free hand because the electrode ( welding rod) will get freaking hot....
   / stick welding with fixed lens #3
Just confirming you are flipping the hood down with your head and neck instead of one hand? What rod are you trying to use- some are hard to strike an arc. Striking an arc is a BIG part of learning to weld. My first welding class had us striking an arc and welding a dime sized puddle over and over and over again.
I would stay away from an old or cheap auto darkening helmet- as you found out it can cause eye problems.
   / stick welding with fixed lens #4
" Do you just simply get the electrode close to the work, flip your hood down and then begin?"......YES
I too have a issue with using the auto darkening helmets. My dad taught me to weld by using 1/4" plywood with a hole cut in it, then a lens was taped over the hole. I'm now retired but still use fixed lens helmets.
   / stick welding with fixed lens #5
I don’t like auto dark helmets. Sometimes I wear one if I have a lot to tack together but I can see much more clearly through a glass helmet. And yes I just move the rod close to the work and flip the helmet down. Another thing you can do is if you have a bright light in place you can see enough through the helmet to start where you want to.
   / stick welding with fixed lens #6
really for the money one can get a auto darkening helmet starting at about $30,
and if you insist on the fixed lens, I find the hand held shield easier to manuliape than a flip down hood, lincoln makes them,
yes about 55 years ago I learned to weld with a flip down hood, but I use the auto darkening so much nicer, only need to learn one thing at a time, not two or three things,
just my two cents,
   / stick welding with fixed lens #7
I’ve used a few different ones and I’ve never been able to see the puddle as clearly as with a glass hood.
   / stick welding with fixed lens #8
I got my first Speedglas auto darkening welding helmet in 1986 IIRC. They were very expensive at well over $100 which was a lot of money in 1986. I did not have a choice of how dark they got, it was preset at about a shade 10. I used it when teaching welding at a local college. It was great for that, I could walk around with my hood down and go up to a student welding without risking arc burn to my eyes.
Now they are adjustable from 8-12. If you were straining with an auto dark hood, then it was likely much too dark, just adjust the dial to #8 or 9 and you should be ok for stick rod welding. #10 is about right for MIG or TIG, anything darker than #10 will strain your eyes unless you are carbon rod/air arc gouging which I dont think any home owner will be doing.
I have had no issues with my Harbor Freight auto-dark hood for the 10 years that I have had in and it only cost me $30. I was in a HF yesterday and they were $39 on sale.
   / stick welding with fixed lens #9
+1 for BDH's post (#6)
   / stick welding with fixed lens #10
Boy, I sure like my auto darkening helmet. Never was a fan of having to nod to weld going back to my college class days or using a buddy's equipment. My first purchased helmet was a HF auto darkening (I think about $40). Just didn't seem right. Returned it and bought the cheapest I think ($99) Miller auto darkening and it seemed far better. Don't know if the HF was flawed but the Miller seemed easier on my eyes. I do wish I had a larger viewing area that comes with the more expensive models, but it is hard to justify for a hobbyist welder that doesn't sell much of anything I fab.
To each his own... but I just don't see why someone would want a fixed (not auto) and non adjustable darkening lens. :confused3:
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
For Sale, Shrink Wrap Kit for implements, tractors, boats etc.
For Sale, Shrink...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
10222 (A56858)
10222 (A56858)
