Sticking throttle on 1920
   / Sticking throttle on 1920 #1
billfires
Southeastern Mass
New Holland 1920
Went to start the 1920 this a.m. and would start and die. I tried throttling up and when it caught the rpms were at 2200. Shut it down and I thought the throttle cable was sticking but it was actually the throttle (on the motor). I sprayed it with WD40 and it returned to normal idle. It is kind of hard to see the throttle so I'm wondering if I need to do anything else. It is a 2000 model with 362 hours on it and has been parked outside since April (long story). Thanks for any help/info, Bill C
   / Sticking throttle on 1920 #2
Open the hood; remove the side engine cover. Set the hand throttle at idle, spray the throttle shaft where it enters the injection pump with your favorite penetrant. Work the throttle shaft/lever from idle to full throttle briskly until the return spring positively returns the shaft to the idle position. Repeat spraying during the process. You should be good to go.
Thanks Rick, I sprayed it some more with WD-40 and it seems to be back to normal. Test will be after I'm released from blizzard coverage at the fire station. Thanks again, Bill C
   / Sticking throttle on 1920 #4
WD40 or Release All is fine. Just don't use Fluid Film or similar stuff. That will gum the cable or the throttle right up. Been there done that including the in-laws. /forums/images/graemlins/wink.gif
Rick, throttle is working as good as new, thanks for your help. Bill C
DieselMonk, used the WD-40 and it's back to normal. Thanks, Bill C
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
