sticky gas pedal
   / sticky gas pedal #11
I've tried the adjustment.. the lube.. the grease and have had it to the dealer twice and it still sticks!
John
   / sticky gas pedal #12
</font><font color="blue" class="small">( I've tried the adjustment.. the lube.. the grease and have had it to the dealer twice and it still sticks!
John )</font>
Gee one more time and it qualifys for the lemon law /forums/images/graemlins/grin.gif
   / sticky gas pedal #13
I would suggest You try the neutral adjustment if it is out of warranty.if it under warranty, then dump it in Kubota's lap.
   / sticky gas pedal #14
Ok, I figure try what is easier first, then go to the next step. Mine was the forward and reverse had to just be adjusted via the palte by the tire. Then he adj the tention on the spring (stiffness of pedal).
   / sticky gas pedal #15
Tomnky... I performed the neutral adjustment but it did not help. I've given up and will learn to live with the situation. The dealer had it for a week or so a few months ago. They said that they worked with Kubota to get the problem resolved. It is a little better but it still sticks sometimes.
John
   / sticky gas pedal #16
I agree a stay at the Dealership can be long as Mine set at one for six weeks with a defective valve.
Was this the adjustment where you jack one wheel off the ground to adjust?
   / sticky gas pedal #17
tomnky... Yes, that is the adjustment. It is very easy to check it. If the neutral adjustment is off you will get creep when there is no presure on the pedal. My problem is that the pedal does not return to neutral as quickly as it should. Sometimes you have to push on the pedal to get it to return to neutral. Once it gets to neutral the tractor does not creep.
John
   / sticky gas pedal #18
you could also adj the tenstion on the pedal too.
   / sticky gas pedal #19
gsxr1100.. I haven't tried shortening the spring. I will try that now that I have given up on the dealer.
John
   / sticky gas pedal #20
Outside of that, you did all that I know of.
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2016 CHEVROLET 3500HD SERVICE TRUCK (A54756)
2016 CHEVROLET...
44029 (A51692)
44029 (A51692)
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
