Stihl Gas and Oil Caps
   / Stihl Gas and Oil Caps #41
Why mess with them. Buy a Husqvarna I have five of them, keep your Oregon chain sharp and use a good quality bar and chain oil. Keep the chain out of the dirt and they cut forever.
For folks that do not know how to sharpen chain buy the new Oregon Powersharp bar and chain system as a retro fit. You will be really surprised. It make a sorry saw a good unit.
Ultraglide62:
:rolleyes: :drool: :cloud9: nothing against an oregon chain but the stihl chain will easily out last it. As far as saying why mess with a stihl,....well why mess with a husqvarna, I've seen plenty of issue's with them. Don't really want to get into a P'sing match about who's mommy wore army boots but I think you're a dealer{maybe weekend warrior} not an operator????
   / Stihl Gas and Oil Caps #42
Talked to a stihl trouble shooter today, he said take in the cap to your dealer with the SN and you will get a replacement cap free of charge
Do you know if this goes for any Stihl saw with the flip cap?
Could you get a pic of replacement cap or a technical bulletin please.
Thanks. :thumbsup:
I waited and waited for it to show up here and finally found the recall on stihl site under flippy caps. :laughing:
STIHL Toolless Cap Safety Recall Notice | STIHL USA
   / Stihl Gas and Oil Caps #43
I prchased a Pro Mac in the late 70's. Served me well, always needed dorctoing in some way though. ex: When the demand thumb push rod to oil the bar gave out I removed it an let the oil run freely. Had to switch to using used motor oil rather than bar and chain oil because it got pricey. I can tell you that bar an chain was exceptionaly well oiled. The new rule was, "no ideling". Cause the oil just kept comming.
Moved up to a Stihl Farm Boss - the 260 I believe. Good saw, still have it.
While tyring to take it easy on the threaded caps I went a little too easy and ended up with a leg and boot soaked with oil.
My son was the on the other end of the extreme. "Things like this only require more power". So he applied more power. Snapped the flange off the top of the cap and drove the threaded portion down inside the resivoir. He is still learning that fine point between required power to achieve the task and, "Oh ****, I just stripped out something else. Those treaded caps are not cheap.
   / Stihl Gas and Oil Caps #45
Got my recall today for the backback and pole saw.
   / Stihl Gas and Oil Caps #47
Any insight on why they don't replace the saw caps with this recall. They all are bad.
Yep. They would have to either replace the gas/oil tank or figure somewhat to replace the filler necks. Assuming you meant 'replace with screw caps".
I've been running saws with them since they first came out. Have thee saws that have eaten 10+ cords/yr. I have no trouble with them...other than forgetting to reinstall them. Just "gased" my pants leg again 2 days ago.
Harry K
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
White Metal Roof Panels (A55758)
White Metal Roof...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
19010 (A55851)
19010 (A55851)
