Still no luck finding aux. wires on my BX22
   / Still no luck finding aux. wires on my BX22 #1
bellweather
Platinum Member
Western MA
Kubota BX22
With apologies to Jim Becker, I still can’t seem to locate the aux connectors for hooking up a work light. After digging, and picking away at the electrical tape and corrugated plastic wire-harness shield, and generally making a mess of things (see attached pic), I still uncovered no connectors. So either my BX22 has no aux connectors, or I’m looking in the wrong place or else I’m just giving up to easily. It is a really tight spot …there is zero slack in the wire harness, and it is tightly wedged between that hydraulic pipe and the chassis. Any suggestions would be most welcome. Thanks.
   / Still no luck finding aux. wires on my BX22 #2
pluck out the red wire that is sticking out and you will have it. It is bundled in the harness where it forms a "t" or "y"... your choice of letters depending on how you look at it...
   / Still no luck finding aux. wires on my BX22 #3
Here's a pic of my wiring before I stuffed it in that corrugated flex pipe. Hope it helps!
Thanks for the help guys. I am assuming that the red wire in question is actually the red and black striped wire? I guess I need to do a little more surgery to free everything up. Kubota sure makes this hard.
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
SDLANCH ELECTRIC GOLF CART (A53843)
SDLANCH ELECTRIC...
HIGH-END MINI GOLF CART (A53843)
HIGH-END MINI GOLF...
Mongo Mover Aluminum Hand Truck (A52377)
Mongo Mover...
