Still No Spark 1950 8N 12v conversion.
   / Still No Spark 1950 8N 12v conversion. #61
hard to find those pills anymore.. I just finished up a tube of bosh cam lobe lube.. lasted me 10ys.. just got a new tube of ML1 from napa... had to tell the parts 'child' behind the counter how to order it.
yep.. and speaking of dwell and timing.. and front mounts. hard (fun) to do without a lil re-engineering on that warded lower primary to points connection.. :)
soundguy
Wooo Whooo!!!! Put the new starter in and it fired right up on the first push of the button like it use too. So after I got the fire back in her (due to grounding through the dizzy. ) I guess it was just the spark plugs all mixed up.
But thanks again for all your help.
It's up for sale if anyone is interested. Let me know!!!
http://oklahomacity.craigslist.org/grd/2532461839.html
1950 8N With 5' Brush Hog Runs Strong lots of new parts!!! - $2600 (Moore)
Date: 2011-08-05, 9:43PM CDT
Reply to: sale-swvvt-2532461839@craigslist.org [Errors when replying to ads?]
I have a 1950 8N tractor and 5' Taylor Brush Hog (with service manual) let me list all the new parts with in the last year.
suspension seat with side guards (worth its weight in gold)
cap
rotor
wires
plugs
points
condenser
coil
battery
oil cap
alternator (life time warranty)
(brand new this week) starter
oil gauge
amp meter
prof meter (it broke with only a few hrs on it Tractor Supply said they will exchange it for free since it has so few hrs on it)
proof meter cable
ignition key on/off
gas cap with gauge
PTO Shaft
I do all the repairs and preventive maintenance even before it's called for. This is a good running and strong tractor. Starts right up even after sitting awhile. Even in the winter time!!! The tires are amazing!! I'd say 90% all the way around. Under gas tank insulated. Solid steel front bumper. Very solid tractor. No rust except surface in just a hand full of places. The bush hog cuts great!!! blades and gear box in great condition too.
Now the not so good ( these aren't too bad but I want to let you know up front) Hydraulics work but have a slow leak down. I have chains on the back so once I get it to the level I want I put the hydraulics all the way down so I don't have to put extra stress on the hydraulics (something I think everyone does). Then like I mentioned the proof meter. And lastly the tail wheel could be replaced.
This tractor would be great to make a few extra bucks on the side.
$2600.00 OBO (FYI not in a big hurry to sell so no low ballers)
Call or Text me Brian @ 405-812-8581
If you have questions feel free to call (before 10:00pm please)
Thanks for looking
it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2532461839
   / Still No Spark 1950 8N 12v conversion. #63
Congrats, glad you got it running.
   / Still No Spark 1950 8N 12v conversion. #64
good luck!
i'm envious that your TSC sells proofmeters.. my local one don't.. :)
soundguy
good luck!
soundguy
They have to order it but no it's not something they keep in stock.
   / Still No Spark 1950 8N 12v conversion. #66
ahh.. not a norml stock item. a special order item.
soundguy
from the sounds of that I should just go ahead and replace it. Actually I think it would be better if I did that. It takes nothing to do it and about 5 min to install it. And that would be 1 less "bad" thing on the list.
   / Still No Spark 1950 8N 12v conversion. #68
if it's a free replacement I would.
saves the new owner from the hassle of trying to track the 'free' replacement down.
I've been burnt that way before.. bought a tractor with a new but bad battery.. was a napa battery.. he got it at the local store.. the manager told him to bring it in and it would be swapped. no big deal.. I went there tot hat store.. manager didn't recognize moe.. no swap.. :(
soundguy
2021 Toyota Corolla Sedan (A56859)
2021 Toyota...
1999 Freightliner Century Class 120 Sleeper Truck, VIN # 1FUYSSEB6XL968818 (A57453)
1999 Freightliner...
Kubota L4701 (A53317)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2019 Range Rover Super Sport AWD SUV (A56859)
2019 Range Rover...
