Storage outdoors
   / Storage outdoors #1
botayota
CT River Valley - NH
Kubota L3240Hst
I ususally store my equipment inside the barn or garage, but I am running out of floor space, so I am planning on putting my Brush Hog outdoors and leaving it there. I have some wood pallets so will be setting it on those, and I also will put a couple of tarps over it. Any other ideas for storing attachments outdoors? Should I remove the drive shaft from the Brush Hog, or just make sure it is well greased, and cover it ?
Clint
   / Storage outdoors #2
Tarp is good. Do make sure that the cutter gets enough air circulation under the tarp since it sits pretty low to the ground (even on a pallet). Will it be on a paved surface or bare ground?
If the drive shaft is not too difficult to remove, storing it inside will prevent blowing dust/dirt from collecting on the greased up parts.
   / Storage outdoors #3
Just grease it good and dont worry about it..
   / Storage outdoors #4
I Leave all My Impliments outside , allthough I Have Plenty of Out Buildings to Store Them in , They are to Full Of junk to get Anything else in there , Including Wasps :eek: .
On The Bushhog & Finish Mower Decks I Just Make sure All The Grass is Off of them, & Put a Trashbag over the End of the PTO shaft with a tye rap . The Post hole digger Is Just Hanging From a Tree & Also the Shaft is Covered .
I Do Try to Keep the Tractors Inside in the Winter though Where its Warm , So Its not so Hard on Them When Needed for Snow Removal . Works for Me so far . Bob
   / Storage outdoors #5
If it has a stump jumper and an access hole inthe deck to get at the blade bolts, stuff a racket ball into the hole to keep water from pooing inthe stump jumper.. if you remove the drive shaft. a bucket makes a great gearbox cover!
soundguy
71056 (A49346)
71056 (A49346)
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
