Storing plow
   / Storing plow #1
mayer2323
After using my plow I coat it with greese for storage ,but I still get rust areas. Is there a better product to use or way to do It?
   / Storing plow #3
I've always used a brushed on coat of used motor oil. I've also heard of folks that apply a light coat of enamel spray paint ...
   / Storing plow #4
I always coat everything with used hydro / motor oil blend that I salvage at changes :D I even coat my metal parts on my tractors with it! Painted surfaces and all.........I know it helps.......I see the results between seasons.
   / Storing plow #5
i sprayed a light coat of paint on mine. As its been said before, paint is slicker and will rub off quicker than rust the next time you go to use it.
   / Storing plow #6
Wire brush,good washing,good primer spray paint,plow off the ground,tarp...works well.
   / Storing plow #7
My local Rural King and TSC carry a product in a spay paint can that goes on like flat black paint and wears off during use just for this purpose.
Chris
   / Storing plow #8
Chris
I believe what you are talking about is called plow coat. I have used it in the past but I have real good luck with grease myself. Plow coat seems to work real well too.
   / Storing plow #9
we always used grease from a bucket we kept just for that with a big paint brush. stays on even in the rain, comes right off soon as you drop plow in ground.
   / Storing plow #10
Fluid Film or LPS 3 are my favorite rust prevention sprays. Ive had great luck with both.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
International 806 2wd Tractor (A52128)
International 806...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
8' GREEN CHAINLINK FENCE (5) ROLLS (A51244)
8' GREEN CHAINLINK...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
