Straighten a trailer axle
   / Straighten a trailer axle #1
MESSMAKER
Bluegrass,KY
DK4710SE
I noticed that one of my wheels on my trailer is suffering from a bit of toe out. I suspect I hit a culvert or something. My friend said he had you can bend the axle pretty easily with a chain and a jack, but has never done it. Anyone have any experience with this. I am interested in giving it a try before I buy a new axle.
   / Straighten a trailer axle #2
Personally I would take it to a truck and trailer shop. They have hydraulic rams mounted to a frame for straightening trailers much like a frame straightener at a body shop. I get trailers aligned for $80 a axle at mine.
Chris
$80 would be a no-brainer. I am not sure they will do it that cheap around here. Only a few body shops left and they don't seem interested in smaller jobs.
   / Straighten a trailer axle #4
I would buy the axle. A little off and you spend the $$$$ in tires.
   / Straighten a trailer axle #5
I have done it with the chain / jack method. Not very precise. I prefer to use a press. The last one I did was with my D3 cat, crude but it worked. I have over 5000 miles on it with normal tire wear. Lots of measuring and time. CJ
   / Straighten a trailer axle #6
Price a new axle , depending on the size =they arent that bad , what you save in time is worth it
   / Straighten a trailer axle #7
No experience on axles, but saved these just in case. :D
I got a bit more info. Chain from end to end fastened to the axle and a floor jack in the middle and crank on it until everything lines up. Does not sound too hard.
   / Straighten a trailer axle #9
You need to find out where it is bent first.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A57024)
Neckover GL24-2-7K...
gravely riding mower (A55758)
gravely riding...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2018 Ford Transit 250 Cargo Van (A55852)
2018 Ford Transit...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
