Straighten a trailer axle
   / Straighten a trailer axle #1
MESSMAKER
Bluegrass,KY
DK4710SE
I noticed that one of my wheels on my trailer is suffering from a bit of toe out. I suspect I hit a culvert or something. My friend said he had you can bend the axle pretty easily with a chain and a jack, but has never done it. Anyone have any experience with this. I am interested in giving it a try before I buy a new axle.
   / Straighten a trailer axle #2
Personally I would take it to a truck and trailer shop. They have hydraulic rams mounted to a frame for straightening trailers much like a frame straightener at a body shop. I get trailers aligned for $80 a axle at mine.
Chris
$80 would be a no-brainer. I am not sure they will do it that cheap around here. Only a few body shops left and they don't seem interested in smaller jobs.
   / Straighten a trailer axle #4
I would buy the axle. A little off and you spend the $$$$ in tires.
   / Straighten a trailer axle #5
I have done it with the chain / jack method. Not very precise. I prefer to use a press. The last one I did was with my D3 cat, crude but it worked. I have over 5000 miles on it with normal tire wear. Lots of measuring and time. CJ
   / Straighten a trailer axle #6
Price a new axle , depending on the size =they arent that bad , what you save in time is worth it
   / Straighten a trailer axle #7
No experience on axles, but saved these just in case. :D
I got a bit more info. Chain from end to end fastened to the axle and a floor jack in the middle and crank on it until everything lines up. Does not sound too hard.
   / Straighten a trailer axle #9
You need to find out where it is bent first.
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A57024)
2012 New Holland...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55314)
BOSS 990 Fuel...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
