Danno1
Veteran Member
It looks like some kind of rivet to me.
I need to remove a metal plate from the tongue of my MF 1734 round baler. It is held on by 8 carriage bolts, the heads on the inside and the threaded ends pointing out. Instead of normal hex nuts, the bolts are secured with cone shaped nuts which I have no idea how to remove. They were screwed on and tightened with some sort of tool. I'd like to get them off without using the sawzall. Any ideas?
Thanks.
Here are some photos: side view, top view and how the nut & carriage bolt look together. As you can see, there's nothing to grab onto: there must be a special tool to do this...
It's hard to tell from the photo ... But I would say the fasteners are either Huck bolts or Magna-grip lockbolts. Either type... the only way to remove them is to destroy them. Grind or torch them off.
It must have been easier or quicker than welding.
