Straw over seeded lawn??
   / Straw over seeded lawn?? #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
I plan to seed some grass over a 120ft by 70ft area. I've seen people put down a layer of straw over the seed. What is the purpose of this and should I do the same?
Jerry
   / Straw over seeded lawn?? #2
I think the purpose of the straw is to help keep the seed from blowing away in the wind. Of course, if you're keeping the ground moist all the time, it may not be a problem. But the straw certainly wouldn't hurt, and it just decomposes and/or gets cut up when you do your first mowing.
   / Straw over seeded lawn?? #3
I've used straw for all grass seeding I've done and it works great. The purpose is to keep the sun from drying out the seed and soil and keep the moisture in. Don't put it too thick or the seed won't get enough sunlight to grow. I just take a "slice" of the bale about 3 or 4 inches thick and shake it so the loose straw falls on top of the seed. When I'm done I have a loose layer of straw about 3 or 4 inches thick. Then water it down good and keep it watered every day for at least 2 weeks. You really can't water too much. The straw will stick together better and won't blow away if it's wet.
Just as a guide, I did an area about 90 feet by 40 feet last year and it took 3 bales. A little thicker might have been ok, so maybe 4 bales would have been better.
   / Straw over seeded lawn?? #4
I agree with Mosey on the purpose of the straw. It shades the ground a little and keeps moisture from evaporating to quickly.
I haven't put down as much as Mosey. The key is to get down as much as possible to shade. I planted about a 1/8 acre of grass this spring and probably should have used more straw (we ran out). A couple of the areas were blown clear and the seedlings dried as a result. Easy to fix and not a big deal.
Terry
   / Straw over seeded lawn?? #5
I think that people also use straw to try to keep rain from washing all of the seed into the lowlying areas and off of the high spots. Sounds like real solid thinking to me.
   / Straw over seeded lawn?? #6
Another thing to do is after putting down the straw and watering it in good, walk over it some. This will help push the straw into the ground and keep it from blowing away. It probably also helps get good ground contact for the seed. I had heard that you couldn't over water it, but found out that you actually can. After the lawn is established, it is usually best to use more water less frequently. While the seed is germinating, the opposite seems to be true, from my experience. Don't lay down too much water all at once. If possible, give a lighter watering in the morning then another in the evening. My first lawn was a disaster. My most second lawn turned out much better, much faster, and with a lot less work.
Kevin
OK, I need to get moving this weekend on this project. Soon it will be so hot out that I won't be able to keep the seed from drying out whether I have straw or not.
Thanks for all the good info.
Jerry
   / Straw over seeded lawn?? #8
A HAND SHAKEN BALE WILL COVER APPROX 500SQ. FT. LIKE HAS BEEN SAID TAKE A "SLICE" OF BRIGHT DRY STRAW IN EACH AND ACT LIKE YOU ARE DRY FINGERNAIL POLISH.
WHEN LOOKING AT THE GROUND I LIKE TO SEE HALF DIRT AND HALF STRAW. just realized the caps sorry.
   / Straw over seeded lawn?? #9
Jerry,
I live in farm country and we always use hay to cover newly seeded lawn areas. Keeps the seed from blowing away, holds moisture after watering and shades the seedlings when they germinate. For larger areas we use a machine called a bale chopper. You load a full bale of hay into the top of the machine string and all and it chops and blows the hay on the seeded area. You can pull the unit around with a larger lawn tractor or they make a distribution hose which will blow the shredded hay about 15 feet. Try any rental center.
Biggest thing to remember when starting a new lawn is to spread starter fertilizer on when you spread the seed. The fertilizer actually coaxes the seed to germinate and then it feeds it afterwards.
I like Scotts products but any starter fertilizer or fall fertilizer will do. Just make sure that the nitrogen level is low (that is the first number on the bag ie. 20-10-5 = 20% nitrogen)
Good luck and remember that if the seeding fails you can always put down sod....just remember ""Green Side Up"
Dale
   / Straw over seeded lawn?? #10
Another reason we use straw (or peat moss) to cover a newly seeded lawn is to keep the birds from running off with all of your new seed. If left uncovered your new lawn with become the local aviary.
   / Straw over seeded lawn?? #11
yup on the aviary!
Last year I seeded my yard, $60 bucks worth of seed. I live next to a small lake. It wasn't an hour after seeding I looked out and there were 30 canadian geese inhaling my seed! I chased them off and within 20 minutes they were back! I spent the better part of the day chasing them off, they were quite indignant! I had to be away for the next week for a work project. Needless to say I didn't very good results on my new lawn.
I put straw on it the next time with much better results! BTW, FWIW I've always heard straw is better than hay because of the higher rate of weed seeds in in hay. Just a thought.
Good luck with your new lawn
Mike
   / Straw over seeded lawn?? #13
This is called seed & mulch, and is a fairly common practice. For best results, seed is broadcast or drop spread, then the hay is spread or blown ( hay blower ) and then is rolled with a special roller that has 'blades' for keeping the hay strands captive in the soil. This also offers a conture line effect, and is very effective at erosion controll. ( When the new grass comes up, it will be concentrated into the rows).
All of our county and state ( florida ) road projects that don't specify sod, must have seed & mulch.
Soundguy
   / Straw over seeded lawn?? #14
Straw is better - decomposition wise too. Around here hay costs at least twice as much as straw .
   / Straw over seeded lawn?? #15
Soundguy,
out west here we have the same rules. All projects whether road building, house building, etc. all require seed and mulch or at minimum straw over any bare soil. We spend a great deal of time concerning ourselves with erosion and its relative impact on the salmon's natural habitat. In many cases it becomes severe overkill (my .02 cents)
The seed is down. The straw is down. And....it's been rolled.
Now, the waiting begins. /w3tcompact/icons/hmm.gif
Jerry
   / Straw over seeded lawn?? #17
I'm envious. Here, hay runs about 3-5 bucks a bale depending on where you get it. Straw is 5.50 to 6.75.
I wish it was the other way around. We prefer straw as well, and also use bales to go over inlet grates for water controll devices to keep them free of debri, yet still allowing water to flow. On the other hand thinking personally, I have cows and horses, etc.. and am glad I can buy hay at 3 bucks a bale /w3tcompact/icons/smile.gif
Soundguy
"Straw is better - decomposition wise too. Around here hay costs at least twice as much as straw . "
   / Straw over seeded lawn?? #18
I agree. Sometimes the county has us do stuff that I believe is counter productive. For instance, we usually sod the berms on a drainage retention area ( or at least seed & mulch ) Which is a good idea to keep it from washing. However, they will also have us s&m the floor of the DRA... then months later they will get us to come maintain the floor ( mow or dredge the vegitation from the floor.... We like the 'found' work.. but seems a tad bit of a waste of tax money...
Soundguy
""habitat. In many cases it becomes severe overkill (my .02 cents) ""
   / Straw over seeded lawn?? #19
Grass seed dies when exposed to direct and constant sunlight. You must provide a top covering for the seed. Straw or Peat Moss works well, the seed must be kept shaded. Heat and moisture are what make the germination go, so don't seed until daytime temps will be in the 70's. Don't use HAY, unless it's Salt Hay....hay contains weed seed.
I think your're right. I put down straw over the seeded area and its growing pretty good now. The areas where the wind blew the straw away are barren. I went out last night and redistributed some of the straw. We'll see what happens.
Jerry
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
14' 10" METAL STORAGE RACK (A60432)
14' 10" METAL...
2427 (A60432)
2427 (A60432)
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
