fried1765
Super Star Member
- Joined
- Jan 6, 2015
- Messages
- 10,089
- Tractor
- Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
I bought an 80's Ford 4100 diesel a couple of years ago and I need to change the transmission fluid. However the plug is stripped, so I can't get it out. It's the type with an inverted 1/2 inch square which was almost completely rounded. I couldn't get any bite with my 1/2 breaker bar so I ordered some extractors. The plug seems to be soft metal as the extractors seem to get a little bit of a bite and then just start eating away material.
I'm not sure what else to try, I was going to try and collapse in the sides so that the threads would be loose but it sits almost flush with the transmission housing so I can't really get much forse from the outside.
Any suggestions?
I would thoroughly clean the inside of that square socket with lacquer thinner.
Then use the proper sized very short socket extension (1/2"?), and epoxy it into the square plug, with either MarineTex, or JBWeld.
You will destroy any future use of the short extension, but will most likely be able to remove the plug.
