JerryG
Super Member
Exactly. Just don't get it on the threads. If your like me, you will have it all over you when your done. I do every time.MJPetersen said:No I would loctite the nut and never seize the shaft!! But I still hope for your sake that you do not have to dismantle it again.![]()
Put the nut and the loctite on first--otherwise you will get the never "sneeze" on the nut and the loctite will not avail.
Mike
Don't forget to put it on the blade pins either. I had to have one pin cut out and have one now that needs it. You have to have a very big torch to cut through that length of metal. It is a wonderful design but they need to put the never seize part in bold print in the manual.
