Stuck shear bolt remnants
   / Stuck shear bolt remnants #1
Ken P
North Granby, CT
Kubota B2410
Folks -
I seem to have snapped off one of the shear bolts holding the augur to the shaft of my kubota snowblower (B2782 if it matters). I guess I must have been continuing to work for awhile, 'cause the snow was pretty packed in on that side when I stopped.
Anyhow, I can't seem to get the remaining piece of the shear pin out. I can wiggle it around a bit, and rotate it a bit with a little metal pick, but it doesn't seem to want to come out. I tried to whack it with a nail set and a mallet without success.
Anyone with suggestions? I tried to do a search, but either this isn't a common problem or my search technique stinks. I could really use some help, many thanks,
Ken
   / Stuck shear bolt remnants #3
I've not had that happen before. I use a punch with a diameter the approx same of the shearbolt which ensures the two holes line up exactly which aids in easy extraction. Using a shearbolt as a punch would work as well if lack of hole alignment is the problem.
   / Stuck shear bolt remnants #4
For shure a drift punch is the correct tool. (I have slightly tapered back about 3/8" on my dedicated drift punch and that helps a lot)
What I found is that soft shear bolts are the cause of that sort of problem.
They fold a bit before shearing due to softer metal and therefore get jammed in place.
I now always use grade 5 for shear bolts and they shear 'clean' when they let go making them easyier to drift out
OK, so I turned on the brute force and managed to whack it out, thanks. I guess I just wanted to have some confirmation that force was the way to go.
Then I went to put in a new one and found that it didn't quite fit, needed to be whacked in. So either something in the hole is scored a bit now (maybe from me continuing to try to blow with the pin busted?), or the shear pins I have are not quite the right size. Perhaps that was why the piece was so hard to get out?
I think it'll work ok now, but if there's anything I should worry about with having to whack a shear pin to get it in place, let me know.
I've ordered some more pins from Tractorsmart, so next time one breaks I can try a different one.
Many thanks for the help.
Ken
   / Stuck shear bolt remnants #6
On my blower the pins are a little snug but tap in easily.
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2005 John Deere 7420 (A60462)
2005 John Deere...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
