Studebaker Trucks?
   / Studebaker Trucks? #31
Nice project.:thumbsup: I'd like to find a red 60s one to restore. Then go to the Gravely Mow-Ins with the prototype Gravely 450 in back. At one point, Stude owned Gravely and Onan.
   / Studebaker Trucks? #32
Cool truck!
Besides joining a Stude forum subscribe to Hemmings and buy a Hollander interchange manual. Even though you're not going to restore it just yet you might want to make a list of the parts you need so when you're at swap meets looking for parts for the Blazer and Chevelle you can keep an eye open for the Stude parts you need.
   / Studebaker Trucks? #33
My dad had one on the farm. It was a six with a stick and freight. No options. Studebaker sold pretty good in our region so there was a fair amount of them around. I think there was a 3/4 ton version also.
Man, that's a neat old truck!
That's and interesting looking intake for a stocker, it looks high performance except for the baby carb on top. lol
It is definately different looking that is for sure, that carb is not the original carb, it is a GM carb. But I have the original Stromberg and it isn't any bigger. lol
Looks like a great find. How did the Nissan do towing it home? Also how far did you have to go get it?
Chris
The Armada did fantastic, it was 399 miles from his house to mine, all highway 84, and was pretty small, sometimes very long hills the entire way. Acutally, I also picked up a new ATV on the way home, I had been planning to get one because I sold my motorcycle. I found a screaming deal on a new Polaris Sportsman 850 XP, so I had that 800lb beast on there as well. Loaded sideways at the back of the trailer. I sure was glad it all fit. :laughing: But the Stude is a heavy beast as well, not sure on the weight, but I would guess at least 5,000lbs. So with the truck, quad and trailer i was close to 8,500lbs and it didn't break a sweat, and rarely shifted out of overdrive. I have come to really love the Nissan. Now if only the d*mn cruise control worked(wheel speed sensor). My leg was sooo cramped after being in the same position for right at 18 hours. Also, with that heavy load, I average 12.5 mpg on the way home at 60-70 mph. Which I thought was fantastic :thumbsup:
The Studebaker trucks were so ugly that they were beutiful! I think part of Studebaker's demise was that they were a bit ahead of their time. Should run good once you get it going. How 'bout some pics later on laying rubber?
They are definately different, I think it is growing on me. I have managed to get the truck running, the firing order was jacked, and had to clean all the points and stuff. And the rotor button was worn out. But after I got it to fire and run, found out that the fuel pump diaphram was rotted, so had to get a new pump. And it didn't come in before I had to come to work.
He may have converted it to 12V, but probably used (or left) a ballast resistor inline to the points and coil. Twelve volts straight to the points will run, but only for a few minutes; you'll probably burn the points up and ruin the coil. Check and see if he doesn't have a ballast resistor on the firewall...
What a find! That's a perfect restore project. And WITH manuals? Too good to be true!
Thanks I actually haven't looked that far into the 6v to 12v thing after i tried a 6v battery and it would just barely spin over. Which is sad because I am an electrician/et. I don't know why, but since I work on electrical stuff all the time, when I am off work it is the thing I hate to do most. :laughing:
Thanks, I read about all the companies they used to own.
Cool truck!
that is some good ideas, but I have never been to a swap meet. I have always wanted to go to one, but just never have. there are never any close to here, but there are some with a few hours drive of here.
Yeah, they made them up from 1/2 ton all the way to big rigs I believe. But they are definately not very common around here. I imagine there are alot more in the midwest, Indiana especially, being they are from there.
I also found out by running the block numbers that mine has the 1955 259" motor. That was the big V8 for that year, which was suprising. There was a 99% chance that it would have the 224" (Economiser) V8, the old man that had it said he was sure it was 100% original, so I don't know if it was ordered that way or not. I read that basically Stude would build whatever you wanted as long as you had the money. So idk. And also I have so many irons in the fire, I really need to get the Blazer done before I do anything with this truck. But I would like to atleast get it running decent. Then I am thinking of putting a quickie hot rod flat black primer job on it, paint the wheels red, a cherry bomb glass pack (you can't even hear it running now) and cruise around town sitting on the block of wood I have been using as a seat. I have the original seat, just needs some new foam and a cover. The ride should be fairly comfortable during these warm days as there will be good ventilation being there is no glass in it. :D
   / Studebaker Trucks? #35
I knew that Nissan would do the job no sweat. I love towing my 7,000# to 7,500# normal load with mine. I get about 11.5 mpg but I have larger tires on the Titan so I am sure that is where I take the hit.
When I first got it I towed the boat just about 50 miles round trip and took it easy, mainly 55mph and saw high 12mpg range.
Too bad about the cruise control thing. Is it still under warranty?
Chris
   / Studebaker Trucks? #37
On a Studebaker?:D:laughing::laughing::thumbsup:
Threads do veer a bit at times!:D I skipped to the last post and saw this!
No, he was talking about the truck he towed it home with.
Chris
Nope, the truck is out of warrranty. It is an 07 with 34k miles. The drive train is still under warranty. But I don't think the wheel speed sensor things qualify. I haven't tried really. It isn't a big deal I rarely use cruise. It would have to be a really cheap fix for me to worry with it. And it usually works until about 60 mph, then it goes out because it senses and difference in wheel speed and tranny speed or some such thing.
Chris
Oh, and DP, if you want to see a truly impressive Titan, go to youtube and search for PapaRyno or something like that. The guy has a white, 4 door Titan LE, stock other than cams, and that thing is an animal. He has videos of drag races beating Lightnings, Chevrolet SS trucks, all kinds of stuff. And I think he has one where he gets up to close to 150mph. That is crazy power with just a cam swap! Makes me think about changing cams in old Armada. :laughing:
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
1000 GALLON ALUMINUM TANK (A52708)
1000 GALLON...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
