Stumped
   / Stumped
It is a 4000 series from 1976 given the serial number and the seat design. I'm pretty foggy on the specifics as I've been away from there for decades now. It looks like the 3-point linkage can be added and you'll be in business. The backhoe hydraulic supply and return lines have been joined and now hang a bit low.
Although tractordata, TractorData.com Ford 4000 tractor information only list the 4000 series up to 1975 I think you are correct Opti-Mist, or close enough. I've removed the old backhoe assembly and currently in the process of fitting up the 3-point linkage. I have also removed the PTO cover to confirm there is a shaft in there so I'm in business. Unfortunately I removed the bolts that hold the cover and oil seal onto the shaft and lost some oil. Does and one know how to top up the level in there or does it fill from the differential oil?
Also, does anyone have any links to a service manual? The hydraulic oil is very dirty and needs changing and I wouldn't mind doing the gearbox and diff while i'm at it.
Thanks again guys. You rock :trophy:
   / Stumped #22
Hi again. The trans is a separate reservoir from the rear axle/hydraulic sump. You should find drain plugs under both the trans & rear axle. Filler plug for rear axle should be on the top right of the center housing and trans on the top cover. Oil level plugs are on the right side of the trans & rear axle at about mid-height. They both take the same universal oil. If there is an external oil filter forward of the right rear axle you might have a common reservoir. This is taxing my memory. Cheers.
   / Stumped
Thanks Opti, I'm aware of the drain and filler plugs, just not sure of the oil source for the PTO shaft. I would have thought it was from the rear axle but it appeared to only have a small volume of oil when I took the pto bearing housing off and the rear axle was still full.
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2013 Dragon Double Rail Roll Off Trailer (A53117)
2013 Dragon Double...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
Hand Truck (A52377)
Hand Truck (A52377)
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2020 RAM Promaster City Mini Van (A53117)
2020 RAM Promaster...
