Stupid Question - What is that rod on the loader?
   / Stupid Question - What is that rod on the loader? #21
I like having it but I have "almost" bent it a few times. I don't go through the forest much so perhaps that is the difference. NOTE: If you are out in the rain just before a big freeze up the rod can freeze in it's tube and bend.
   / Stupid Question - What is that rod on the loader? #22
On my LS the bucket level indicator rod is flush with the top of the OD tube when the bucket is level which is easy to see when it is flat, but you dont get any indication of how far down it is tilted once you tilt it past level. It comes out the top of the tube as you curl it above level which doesnt really tell you any useful info. On my P 7010 C (cab) you must have the indicator as you cant see the bucket lip from the cab, even if you try to raise up and smash your head into the ceiling (did I really do that ONE time?) I may look into extending the rod and putting a groove in it at the level point so I can tell how much the cutting edge is tilted. That would be a good design tip for LS to do.
   / Stupid Question - What is that rod on the loader? #23
You may need to spray that rod every once in awhile, kinda a metal on metal issue. Mine has a squeal detector on it, when it starts to squeal when I curl the bucket it means it is time to lubricate it again. A little wd40 or other spray lubricant will work just fine.
My JD2320 has the same type indicator.:thumbsup: Wonder which company copied who?
   / Stupid Question - What is that rod on the loader? #24
I think it's a good simple design. Everytime I use a machine without one I end up rocking back and forth with the bucket to 'feel' when it's flat. Haven't bent mine ..yet..
   / Stupid Question - What is that rod on the loader? #25
After this past weekend, mine is sort of omega-shaped. I took it off Sunday and will try to straighten it...I've heard that simple rod is bit expensive to replace, though, so I'm going to try really hard to get it straight!
BOB
   / Stupid Question - What is that rod on the loader? #27
My first one ended up as a pretzel. The second already has a bow in it and broken guide shaft. I have simply removed it before I bend it further. I may put it back on when using the bucket to level or dig but having it in place when doing grapple work in brush is just disastrous.
   / Stupid Question - What is that rod on the loader? #29
Definitely upper case! Achieving the lower-case omega would have taken another week or two in the woods, I think.
BOB
I was trying to figure out how it could be lower case, but my imagination failed me.:)
Steve
   / Stupid Question - What is that rod on the loader? #30
Is your grapple big enough?? :D
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
