Sub-Soiler; Depth and Hp.??....
   / Sub-Soiler; Depth and Hp.??.... #11
I don't think you need WEIGHT on it as much as proper top link length to get it to the right angle to sink in.
This is generally true in a majority of arable topsoils. Please note, however, that the OP used the term "hardpack". In my case, below the clay topsoil, I am ripping a layer of Duripan, which is technically classified as rock, albeit soft rock in contrast to say granite. One poster above mentions ripping ever 3rd year or so to break up hardpan. Such soils that repack relatively quickly into a hardpan are technically known as Fragipan. Duripan takes centuries to millinea to reform and is much harder than Fragipan. In my conditions, I have to get the angle right AND have a lot of weight in order for the tooth to dig in. This may be the case for the OP as well-he may need a short top link length as well as BALLAST depending upon how hard his "hardpack" is.
   / Sub-Soiler; Depth and Hp.??.... #12
I am considering getting a sub-soiler to help with water runoff.
Is 24hp enough to get it down 12" into hardpack.??
JDGreen, Good morning.
HP depends on the number of shanks you pull. A single shank may well be able to attain a depth of 24" with several passes in the same trench.
I live in Eastern Wash. and made a sub-soiler using a spring toothed harrow. Narrow single tips, and pull 5 shanks at 16" spacing and can reach 20" in 2 passes with my Jubilee.(approx 28 hp). We have a lot of sand here.
From what I have read, A single furrow on 30" spacing or so, and getting below the compacted layer is the most effective.
My place used to be a horse ranch and the soil was really compacted to about 12". Now it drains well.
Good luck, Dave
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2022 Behnke Trailer (A55973)
2022 Behnke...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2020 DRAGON ESP...
