Subframe brackets 4310-4400
   / Subframe brackets 4310-4400
So, back to my original question which was it said it came with the brackets, and they were on a 4400. I want to make sure they will fit my 4310. Also, my neighbor has a Woods 7500 on his Deere with a 3 point hitch mount, and a seperate pump. He says he likes that better than the subframe mount. What do you guys think? Thanks, shyguy6 <font color="green"> </font>
   / Subframe brackets 4310-4400 #23
OOPS where did I get 4210?@@
Yes it will work.
I don't want to say your friend is nuts, but RSA Aint a subframe and it beats a 3 point to death, the pto pump is a real pain and you don't need it on a 4310.
   / Subframe brackets 4310-4400 #24
Yes it will work.
Okay, thanks a lot. Now I know all about how Deere attaches their backhoes. Thanks for the info.
   / Subframe brackets 4310-4400 #27
I hope I didn't offend with the comment about your friend.
The RSA is a lot harder to initially install than a 3 point hoe. But it is much stronger, and far easier to take on and off after inital instal. And the whole setup was designed to work together.
3 point setups are generic, and if you had a less capable tractor, one of those might be a better choice
I have the 47 on a 4310 and can assure you that it is a terrific setup.
   / Subframe brackets 4310-4400 #28
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
2019 CATERPILLAR 336GC EXCAVATOR (A52706)
2019 CATERPILLAR...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A56129)
2021 MACK GRANITE...
2018 MACK CHU613 DAYCAB (A55745)
2018 MACK CHU613...
