blueriver
Super Member
- Joined
- Oct 4, 2007
- Messages
- 5,012
- Location
- S.E.Oklahoma
- Tractor
- JD 5520 Montana 4340 Farmall Super A Montana 5720C
I'm also thinking if I had the coulters they will cut a good depth and that may inable the shank to get in.
Yes that is good advice and I will mess with that before I make any modifications. If that don't "cut" it ... I'm going to try some weight as well to see if its an issue.
:thumbsup:I envy your skill and you may have something that would sell there. Maybe you could call it the "Triple Sub-Soiler". Notice how it covers your tracks.![]()
This may sound like bunk but...Look at the flat spot behind the point. I built a root cutter/ripper had to roll that sucker WAY over before it would bite. Ended up cutting sharper angle onto tip to get it to bite. Looked at bottom of cutter well pollished spot where back is limiting plunge..
Bad News ... as some of you stated it needs shear bolts ... I did about 5 acres of that hard virgin soil and bang broke the middle shank clean off ... i
