Suggestions for ROPS lights
   / Suggestions for ROPS lights #11
Here's a lighting post with all kinds of ideas and some pics of how I mounted my lights. I think it will go to page four... that's where my pics are.
light ideas
Thanks for all the suggestions! I think for my purposes, which is just for night-time snow removal, I will just use the 2" magnetic mount on the ROPS, with lights plugged into a 12V power outlet (which I want to add anyway). This way, I can remove it when not in use.
   / Suggestions for ROPS lights #13
</font><font color="blue" class="small">( If you drill your ROPS you may as well discard the ROPS as ANY modification voids ANY manufacturer's warranty. )</font>
You're joking, right? The warranty is not what protects you in a rollover, the steel is.
I'm a structural engineer and would not hesitate to drill small holes in the ROPS for lights.
   / Suggestions for ROPS lights #14
I agree 100%. Kubota says that to keep their "rumps" covered because you KNOW that if they say drilling it is A-OK...that some jerk-wad is going to go after it with a 1 1/2" hole saw and "swiss cheese" it to death. <font color="blue"> </font> <font color="red"> </font>
   / Suggestions for ROPS lights #16
I mounted mine with square "u" bolts from Tractor supply. Also used the existing wiring.
I'll post pics when I get home
   / Suggestions for ROPS lights #17
Just finished a simple light bar on my b2630. Constructed with 1 peice of white plastic plumbing pipe, 2 toggle switches, 3 Grote rubber work lights rated at 35 watts/ 2.7 amps each, and some tie wraps. No drilling on tractor required. One toggle switch turns on the front lights, the other does the rear light. -Doug
Speaking of connections, is there any existing wiring that could be used on a BX23 for lights? I hear of an existing 12V connector under the seat of some other tractors. I don't have the shop manual yet, but in the engine compartment, there is an unused socket coming out of the wiring loom, around the top of the engine. What is that for?
   / Suggestions for ROPS lights #19
Call me extravagent but I bought Kubota lights. They come with nifty painted brakets and square U bolts so no drilling is required. They also have a switch on them which is nice since the spare wiring for external lights is hot when the key is on rather than with the light switch. I thought that a bit odd.
   / Suggestions for ROPS lights #20
Under the seat there are two blank "pigtails" which are ignition-on 12 volt leads. I used this 12 volt source for power and spliced into the tail light lead for the switch side of the relay. So, when I turn on the "headlights" my work lights come on too. They also go off if I turn off the ignition switch.
See where I mounted my relay on my website in the previous post.
2019 Ford Explorer AWD SUV (A55758)
2019 Ford Explorer...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
SHOP STAND WITH CONTENTS (A55745)
SHOP STAND WITH...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
Eagle Weathervane (A55758)
Eagle Weathervane...
