Larry_Van_Horn
- Joined
- Jul 15, 2003
- Messages
- 271
- Location
- Honeoye Falls, NY
- Tractor
- Case 580D Backhoe, NH TC40D SS, JD 450BC dozer, Ford F700 dump
Folks,
I am building my topsoil screener and will have pictures soon. The basic design is 6x6 posts at each corner, connected by lag bolted 2x10s to produce a 6x8' square 8 ft high. I then have welded up a tray of that dimension and secured 9 gauge mini-mesh chain link fence to the tray. I suspend this from the posts with chain so that it hangs on an angle. I want to be able to dump 1000 pounds on it at a time.
Now for the question - how to get the tray to shake. I purchased a Vibco pneumatic vibrator but it was too small to make it shake. I might try a larger one, but they said that even the larger 55-2 piston vibrator might not be enough to get it moving. So I figured I might have to get a small gas engine and do the off-center pillow-block thinggy. I am just not clear on how this is designed and worked out. Anyone have any suggestions or designs for getting this thing chaking cheap? I have searched and looked at all the posts here but don't have the clarity I need.
I will post pictures of this thing when I get it done.
Thanks,
Larry
Thanks,
Larry
