Sunpro Oil Pressure Gauge
   / Sunpro Oil Pressure Gauge #11
Well, I'm in the process of installing the Sunpro 1-1/2" gauges on my 1700. I've had a heck of a time in getting the adapter kit /forums/images/graemlins/mad.gif. The local Auto Zones don't carry them /forums/images/graemlins/confused.gif. I ordered through Jegs but they were backordred, so I cancelled and ordered through JC Whitney. Hope to get the mounting plate machined out this week to install. Great forum.
   / Sunpro Oil Pressure Gauge #12
Yikes.. that's bad luck. Here in florida, our local stores ( the 2 where I live anyway ), have the metric adapter kits right ont he wall, also next to plastic and copper tubing as well.
Good luck !
Soundguy
   / Sunpro Oil Pressure Gauge #13
I was able to find the adapter kit for the oil pressure gauge with no problem. But the water temp was hard to find. Finally got it at NAPA, a little pricey, but probably half what I spent in gas driving all over town. Good luck!
The meter pretty much bounces up and down so fast that it is just a blur. It gets worse at higher RPMS. I don't think it is showing me oil pressure variations. I will try the smaller orfice. I will also try and disconnect the gauge from the tractor and hold it in my hand, see if that makes a difference.
   / Sunpro Oil Pressure Gauge #16
</font><font color="blue" class="small">( The meter pretty much bounces up and down so fast that it is just a blur. It gets worse at higher RPMS. I don't think it is showing me oil pressure variations. I will try the smaller orfice. I will also try and disconnect the gauge from the tractor and hold it in my hand, see if that makes a difference. )</font>
I'll be suprised if holding it your hand is any better. Sounds like you might be onto something with the smaller orifice to dampen the pressure variations. I didn't have to add anything special to mine, but I do remember one of the adapters having a very small hole, maybe designed to restrict the flow? Not sure. I think it was the one the copper tube screws into. Then that fitting screwed in to the metric adapter. I'll attach a picture, maybe it will help.
   / Sunpro Oil Pressure Gauge #17
Well, the gauge install saga continues /forums/images/graemlins/blush.gif. I finally found the adapter kit in Texas and they are sending it out this week. Purchased a hole saw at Northern tool but Lowes didn't have the bit adapter /forums/images/graemlins/crazy.gif. So...I returned it to Northern and purchased a 1-1/2" metal hole saw from Lowes /forums/images/graemlins/smile.gif. Well, guess what. It's too small /forums/images/graemlins/frown.gif. Needs a 1-5/8" for the 1-1/2" Sunpros /forums/images/graemlins/confused.gif. So, I go to Lowes again looking for a 1-5/8" hole saw. Nothing. Nada. Don't have them. Looked at the dremels but didn't want to spend the money being a tightwad that I am. So...I resigned myself to the fact that I was gonna need to file out the inside of the holes for the mounting plate /forums/images/graemlins/mad.gif. Decided to take one last look at the hole saws in Lowes and guess what...found a 1-5/8" hole saw laying in a column beside the wall of saws /forums/images/graemlins/grin.gif. Discontiuned item but boy was I lucky to find it. Guess you learn from things like this. I usually end up going back and forth to the hardware store several times before I get everything I need anyway /forums/images/graemlins/smirk.gif.
   / Sunpro Oil Pressure Gauge #18
On mine, I chucked a garnet hone ( 50 cents at the flea market), and rounde dout the holes made with a 1.5ID saw, to fit a sunpro.. doesn't take much.
good luck
Soundguy
   / Sunpro Oil Pressure Gauge #19
When I installed the 2" gauges on mine the holes needed to be 2"1/16. Impossible to find. I used my dremel tool with a stone. It only took a minute to widen the hole.
   / Sunpro Oil Pressure Gauge #20
Well, I cheated...Took it to our machine shop here on campus and got her drilled out to 1-5/8". Sometimes working at a community college has its advantages /forums/images/graemlins/smirk.gif.
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
2015 KENWORTH T680 (INOPERABLE) (A52472)
2015 KENWORTH T680...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
