super udt hydraulic fluid
   / super udt hydraulic fluid
Isn't the regular fluid 20W ? if so the super is just a heavier grade fo the same stuff at 30W.
   / super udt hydraulic fluid #12
I know the Super UDT is a synthetic. I'm not 100% positive but the regular UDT is not synthetic.
That makes the increased cost more understandable.
   / super udt hydraulic fluid #14
do you need to drain all fluid from hoses and pistons to go back to super udt? It states not to mix it with any other brands. If system is not completly drained you will end up with a mixture of both correct.
   / super udt hydraulic fluid #15
I just priced the amsoil hyd/trans synthetic 5 gal bucket at $61 plus shipping with a comercial account setup. I thought I was reading that super UDT was about $60 for 5 gals. So I'm just going with the super UDT from kubota.
Eric
   / super udt hydraulic fluid #16
I find it odd that they say not no mix types when we have synthetic blends everywhere.
I had the cylinders contracted and pulled the drain plugs. When pulling the plug to drain the lines from the loader probably didn't get half a cup out of it.
I just bought a 2.5 gallon bucket of UDT from the dealer and he charged me $38.18. I think these dealers make significant profit on UDT.
John
Ctyler,
All synthetic oils are not made the same way. So mixing might not be a good idea.
Yeah Jwe,
I wonder if some of the generic types of tranny fluid and the dealer brands ome from the same vat ?
Of course the dealsers say no, but they have a vested interest and so does the oil company, so who knows.
   / super udt hydraulic fluid #20
Lets play devils advocate for a minute.
Lets say you have brand X non-synthetic and brand Y that is a synthetic. Both X and Y are approved to be run in the tractor. Now you mix the two. What is the issue, they don't mix well? Would it make a difference since either one is ok to run in the tractor?
35176 (A53424)
35176 (A53424)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
