gerard
Veteran Member
See if you have a coal supplier near you. I have a dual use furnace (oil or wood) and I burned wood the last two winters. Nice even heat BUT cleaning the flue and heat exchanger every 6 weeks, hauling the ashes AND dumping 10 cord of wood down the garage shute to the basement and then stacking was too much. This year I'm going with straight oil. (This leads to the coal) As a "test" one year I bought a few hundred lbs of coal. Worked great, nice steady even heat and only had to add about every 18 hours. Problem was without the shaker greats the clinkers would build up and you had to let it burn down after a few days and clean it out. Thye make stoves just like the pellet stoves but that burn pea coal. Same idea - fill the hopper and forget about it. Don't think you get the creasote buildup with coal either. I would have bought the shaker grates and went to coal but they wanted $300 which was too much. Just something else to think about........../w3tcompact/icons/smile.gif
