Suspension bridge design
   / Suspension bridge design #32
Rock knocker said:
That sure looks like a W
looks W to me too. But I forgot to look it up before i left work. I'll have to see if i have a copy of the machinists handbook at home.
   / Suspension bridge design #33
I would put a new wooden bridge in the same place as the old one, but add horizontal suspension cables so it doesnt float downstream in a flood. Much less complicated and pricey than vertical suspension. Especially when you dont have an anchor point nearby. KISS ;)
   / Suspension bridge design #34
A little larger than yours, but sometimes the experts don't get it right.
Same problem (yet smaller, not catastrophic) happened a couple of years ago here in Holland with the newly built Erasmus bridge.
Erasmusbrug - Wikipedia, the free encyclopedia
Shortly after the bridge opened to traffic in October 1996, it was discovered the bridge would swing under particularly strong wind conditions. To reduce the trembling, stronger shock dampers were installed.
If i remember correctly from the news back then, first the problem was patched by adding cross tie wires between the vertical pullcables. After analysis they came up with different shock dampers to change the natural frequency.
   / Suspension bridge design #35
I've never seen a W6x6 before I thought maybe an S. I was trying to get as many pictures as I could before the rain came so I never took a close look. After looking at the picture it's a W.
   / Suspension bridge design #36
That is awesome! Way overkill for my purposes, but really cool none-the-less. Wow, 1 1/4" cables is huge -- extremely difficult to work with. And I thought 1/2" cable over 70' distance was heavy. My wife (and I) wouldn't like the chain-link on the sides. It also looks like they double anchored the end deadmen. Thank you very much for the pictures! More ideas....
Marcus
Only on one end did they double up the anchor cables. I suspect they were worried about the ledge they were anchoring to. I think they took advantage of not having to do the engineering, if they did come from a ski area, since the ski area would know how much weight the cable could hold for a given span. I wouldn't want to handle the stuff but once it's up it would last a lifetime.
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
