Swampy poor drainage area/how to correct?
   / Swampy poor drainage area/how to correct?
I will go by and snap a picture after work today of it and post it but it is basically a low spot next to the creek. It is a good 2-3 feet above the creek but everything slopes down to this spot from the front, side and back of the property then rises back up to the creek bank. This creek is only about 4 ft wide. That is why I was thinking that just cutting a ditch and using the box blade to help slope towards ditch/creek would be easiest. This part of the property is the far NW corner that will not be traveled much and the natural slope of the land takes everything to this one spot so cutting a drainage ditch and sending that ditch to the creek seemed logical to me. I guess I could try that and if it did not work I would already have a ditch started to then make into a trench and put pipe in, etc...for a french drain.
   / Swampy poor drainage area/how to correct? #12
your last post, kinda gave me the hibee jibees. you need to be careful when putting in ditches and more so put in thought about erosion control. it may work for a few years. but after that, it might turn out to be an ugly mess. were you have 2 to 3 feet trench that has been washed away with heavy down pours of rain.
and in that, you might look into seeing about hauling in some good size rocks to line bottom of ditch. or perhaps make it wider vs narrow and deep. so it takes much longer for heavy rains to wash things out and allows you to mow it.
there are a 1000's of ways of going about it, no wrong or right way. but there might be a better way that last longer and less up keep over the years.
to note it, be careful with erosion control.
Boggen,
Thanks for posting that. That is why I posted here. I am new to this and would have never thought of that.
Looks like my best bet would be to install the french drain. I have attached a sketch of the plan.
Obviously this is not to scale and the drain line would run the entirety of the wet area.
  • Drain Plan.pdf
   / Swampy poor drainage area/how to correct? #14
Pond!
   / Swampy poor drainage area/how to correct? #15
*rubs chin*
8" double wall culvert, 55 gallon drum. and good size strong piece of grate. that will fit a few inches on all sides over 55 gallon drum top.
prefer double wall vs single wall culvert, due to double wall culvert has a nice smooth inside, and less chance of sticks and other muck getting stuck inside of the culvert.
if you can burry the culvert 1 foot or deeper so when done there is a foot or more of dirt over culvert, you should be ok, when you drive over the top of it.
the 55 gallon drum. cut hole in lower side of drum to side culvert part way into. cut the top out of 55 gallon drum ((top out, not cut the top off. leave 1 to 2 inches around the edge, this adds a lot of extra strength to the drum so it does not cave in on itself))
drill some holes in bottom of drum. ((this is to make it so, drum will not act like a boat and come up and out of the ground on you))
drill some holes around side of drum. this will allow water to soak into the drum. ((all holes say 1/4" size))
get yourself some spray foam "closed cell type" (example "great stuff, in red can") and spray in between culvert and drum. and let it cure for a couple days. this will give you a descent seal. with some flexing.
put say 6" of gravel below drum, and 1 foot or so wide around drum. ((drainage rock, crushed rock, something to allow water to soak into drum))
at the very top pour concrete say 8" thick 1 foot or side wide all way around drum. ((top of concrete should be level with lowest spot of area))
place a good size / strength grating over top of 55 gallon drum / concrete. so if you drive over spot you do not fall into it. also make sure grating has small enough holes. so no child or animal can fall down into drum. might suggest anchoring the grating down with "concrete anchors and some bolts"
the goal of above, would be like having a bath tub drain. were all water for area runs down into. and exits out into the creek. and there would be no ditches, or ravens, or major wash outs happening. or you could look at it like an "overflow" on a pond or lake. but in this case, you are not wanting any water.
you can do the french drain setup as your diagram posted as well.
or just do a standard culvert, like a culvert underneath a driveway. but between creek and low spot. and just have a larger hole at end of culvert in low spot you will have to watch out for.
if you are not planning on lake / pond. i would say just re-slope / grade the entire area first. and if having mush areas. i might suggest running a french drain / field tile up near bottom of hill sides. so the french drain / field tiles run parallel to the hill side, so water coming down hills hits the french drain / tiles and then every so often run a pipe from french drain down to creek. so the water hits the french drains first. vs water running across flat areas of land.
multi ways of going about it. no wrong or right way. perhaps one would work better for you than another.
Here are some pictures from the area I am speaking of.
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2020 DRAGON ESP...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
