Swapping an L3301 for an MX5400
   / Swapping an L3301 for an MX5400 #1
thunderworks
Kansas
L3301
About 4 years ago I bought an L3301. I use it to mow, grade the drive, haul logs out of the woods. My property is fairly hilly. I added wheel spacers and fluid to the rear tires, but I've never felt completely comfortable with this little tractor. I found a used MX5400 that I think I'm going to get and I'll sell the L3301. I hope the bigger tires, increased weight, and wider stance gives me a broader comfort zone on the hills. The loader and 3pt hitch also have much great lift capacity. I hope this proves to be a sensible swap.
   / Swapping an L3301 for an MX5400 #2
I did something similar L3200, which is just a pre emissions L3301 to a L4060hstc. Not quite as big a machine as you are going to, but close. The economy Ls are definitely a bit light. I'm glad I made the jump. In retrospect I wish I'd gone for a L6060, but not unhappy with the 4060. For my use case I don't want anything really bigger, but others definitely need bigger machines with more stability & lift capacity.
   / Swapping an L3301 for an MX5400 #3
The MX should have "adjustable" rear wheels, similar to the old L5030 you had, and I currently have ... Set them as wide as you can, and fill them.
   / Swapping an L3301 for an MX5400 #4
Happy with my MX5200. It has a low center of gravity. Always run filled tires. Wheel spacers 3" rear and 2" front help.
TAILGATE (A54756)
TAILGATE (A54756)
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
