sweet potatoe harvest time
   / sweet potatoe harvest time #11
I actually like a sweet potato simply baked. Does not need anything on it, good as is.
You have them confused with another veggie!---they are simply "sweet potatoes" ---- also they are NOT yams either!--a lot of people confuse these!
   / sweet potatoe harvest time #14
My neighbor showed on FB using his mini ex to dig his sweet potatoes.
   / sweet potatoe harvest time #15
I'm impressed with the harvasts. And I thought the Puerto Rican Pink I grew that weighed 3 lbs was a big one! Also, I have root cellar envy. I've always wanted one. They are not common in my neck of the woods.
   / sweet potatoe harvest time #16
Handy if you have a hillside to burrow into for a root cellar....but you can build up a mound of dirt to make it. I have a mountain that rises almost 1000' from the lower part of my place to the top. My house is built into it, with the garage having 7' of dirt/shale against the upper side of it. I dug out a hole with excavator, then cut a hole in block wall into the hole.
enhance
Poured by hand a small footer, then laid 8" block to make an 8x10' room.
enhance
Put a temporary roof of 2x lumber, then had the roof poured 6" thick.
enhance
enhance
enhance
Put 2" foam board on top the concrete, then backfilled with couple feet of dirt. Couple coats of paint, shelving and lights to finish off the inside. Also put some 6" Pvc tubes for outside air. One has a small 'duct booster' fan on a timer to draw colder night air in starting in the fall.
enhance
enhance
   / sweet potatoe harvest time #17
That is a beautiful root cellar.
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
KUBOTA ZG222 ZERO TURN LAWN MOWER (A51247)
KUBOTA ZG222 ZERO...
KUBOTA M6800 TRACTOR (A51247)
KUBOTA M6800...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
