synthetic oil help generator start better???
   / synthetic oil help generator start better??? #21
Synthetic will reduce the drag that mineral oil would present at the same temperature.
   / synthetic oil help generator start better??? #22
Not substantially.
If you compare the spec's, the difference in lubricity is not that much.
It's not your fathers mineral oil anymore.
I did say he should use synthetic oil in his generator. It just isn't going to solve this problem.
   / synthetic oil help generator start better??? #23
I'll stick with a real class IV synthetic in cold weather, high temp applications, short duty stop start applications, generators and pumps that start and run to full rpm and air cooled engines.
   / synthetic oil help generator start better??? #24
Howdy,
Running synthetic oil in your generator certainly will not break the bank. It's not like it will use 5 gallons... :)
synthetic and dino oil will run very similar per spec. If you are in the very artic area and plan to need to use the generator and it's -20 degrees out, then you would use the appropriate weight oil. The same thing would apply for someone towards the equator, and the coolest weather they see is maybe 70 degrees, but they need the generator when the average temp is 100 degrees, you would use a heavier weight oil.
Buy some synthetic oil with the proper weight for your area, a oil change won't hurt.
Starting problems... ummm started fine the first few years.... ummm gasoline issues. I would suggest you siphon out as much gas as possible, put that into your car, buy some fresh gas, add a treatment, and run the generator at least an hour with load, and then top off the gasoline again.
   / synthetic oil help generator start better??? #25
Many people "feel" they can tell a definite difference between synthetic oil, and mineral oil.
But, from a scientific standpoint, if you look up the specifications, there is not a significant viscosity difference between a quality mineral oil, and a synthetic oil, until it gets really cold. (Or, really hot).
There is also no longer a significant difference in lubricity either.
If it gets really cold, or really hot, there is a basis for there to be a difference. In normal conditions, there is not. And. that has been what I have experienced.
One example was back in my 1988 Ford 5L V8. Using dino oil of the same viscosity, and always filling the new filter with oil prior to installation, just before the oil pressure gauge would jump up to registering, for a split second I could hear dry lifter rattle. I changed to syn and using the same changing interval, viscosity and all I never heard it again.
So much for data.
Mark
   / synthetic oil help generator start better??? #26
So much for data.
Mark
Yes, people who have the same tractor as me, have occasionally reported they noticed all kinds of differences when they switched to synthetic oil. I use the exact same products, and it did not make any difference what so ever, in it, or any other application I used it in.
Having driven lots of different vehicles over the years, I have had noises can come, and go, for no reason either.
I use Sea Foam on occasion, and have seen it work wonders. However, some TBN members, insist it does nothing.
Your perception is your reality. But, not necessarily a reality for anyone else.
   / synthetic oil help generator start better??? #27
That's true and I reference my remarks, like if it's an experience of mine I say so meaning it worked for me or didn't. If a spec out of a manual I say that too; not necessarily agreeing with it, just stating what's in the book. Agree on what works for the gander might not work for the goose, but then again it just might.
I used Sea Foam in my 2 cycle OB in every tank. One day I had nothing to do and had several 2 cycle machines that were old, quit running and replaced them. In Short order using nothing more than fresh fuel and a significant amount of SF I got the tiller, chain saw, and weedeater all running to suit me. Was surprised SF made that much difference.
Mark
   / synthetic oil help generator start better??? #28
Mark
took the generator apart down to the carb/choke area. checked the choke for full closing and such. it appeared to close properly and all the external linkage to the choke looked to work properly as well.
next, inspected the spark plug. looked good right out from engine, but wire brushed point anyway. then checked the gap. book says .030 inches and the gap on the plug was much tighter then that, so I gapped it at .030". at 68*f temp, it fired up on the second pull. that kinda surprised me it started that quick, but it was warm out. don't know if it was the plug or not. I will buy a new plug that is spec'd for colder running. (book states 3 different plugs for generator all for different temps. still don't know if that might help.)
as for my original idea of switching to synthetic helping, here is the stories I heard of going from conventional oil to synthetic.
one guy told me that he put mobile 1 synthetic in his lawn mower after only running conventional oil in it. the mowers throttle had a "notch" in it where he always run the throttle. immediately after he fired his mower up after putting the synthetic in, the engine was running at much higher rpms at that same notch, he had to back down the throttle to put the rpms back to where they were when the conventional oil was in it.
my friend told me that he switched to ams oil synthetic in his 2005 gmc truck (5.3l) and went from 16-18 mpg (conventional oil) to now, 19-22mpg (synthetic oil).
both people indicated the synthetic oil must create less drag on engine parts, thus their improvements and hence my idea of the synthetic oil creating less drag and helping the generator roll over easier and start easier.??..
   / synthetic oil help generator start better??? #30
By all means try it, it's only a few bucks more.
But, as I have said, if you check the actual specifications, and compare them, you will not see enough difference in any of them, to explain substantial differences in performance. Except in extreme temperatures.
The people who make synthetic oil, do not promise mileage increases like that. Wouldn't they, if it was true?
I have tried Amsoil, and Mobil 1 in several pieces of equipment, it made no noticeable difference for me.
Synthetic oil technology is not the only oil technology that has evolved. All quality oils use the latest, and greatest additives.
People often make claims such as, using higher octane gas, gives you more power, and thus better mileage too. Any gas supplier will tell you that is not true. Once someone decides they believe something like that is true, most are not going to change their minds.
Fork Extensions (A57149)
Fork Extensions...
2159 (A58376)
2159 (A58376)
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
