buickanddeere
Super Member
Synthetic will reduce the drag that mineral oil would present at the same temperature.
Many people "feel" they can tell a definite difference between synthetic oil, and mineral oil.
But, from a scientific standpoint, if you look up the specifications, there is not a significant viscosity difference between a quality mineral oil, and a synthetic oil, until it gets really cold. (Or, really hot).
There is also no longer a significant difference in lubricity either.
If it gets really cold, or really hot, there is a basis for there to be a difference. In normal conditions, there is not. And. that has been what I have experienced.
One example was back in my 1988 Ford 5L V8. Using dino oil of the same viscosity, and always filling the new filter with oil prior to installation, just before the oil pressure gauge would jump up to registering, for a split second I could hear dry lifter rattle. I changed to syn and using the same changing interval, viscosity and all I never heard it again.
So much for data.
Mark
Yes, people who have the same tractor as me, have occasionally reported they noticed all kinds of differences when they switched to synthetic oil. I use the exact same products, and it did not make any difference what so ever, in it, or any other application I used it in.
Having driven lots of different vehicles over the years, I have had noises can come, and go, for no reason either.
I use Sea Foam on occasion, and have seen it work wonders. However, some TBN members, insist it does nothing.
Your perception is your reality. But, not necessarily a reality for anyone else.
took the generator apart down to the carb/choke area. checked the choke for full closing and such. it appeared to close properly and all the external linkage to the choke looked to work properly as well.
next, inspected the spark plug. looked good right out from engine, but wire brushed point anyway. then checked the gap. book says .030 inches and the gap on the plug was much tighter then that, so I gapped it at .030". at 68*f temp, it fired up on the second pull. that kinda surprised me it started that quick, but it was warm out. don't know if it was the plug or not. I will buy a new plug that is spec'd for colder running. (book states 3 different plugs for generator all for different temps. still don't know if that might help.)
as for my original idea of switching to synthetic helping, here is the stories I heard of going from conventional oil to synthetic.
one guy told me that he put mobile 1 synthetic in his lawn mower after only running conventional oil in it. the mowers throttle had a "notch" in it where he always run the throttle. immediately after he fired his mower up after putting the synthetic in, the engine was running at much higher rpms at that same notch, he had to back down the throttle to put the rpms back to where they were when the conventional oil was in it.
my friend told me that he switched to ams oil synthetic in his 2005 gmc truck (5.3l) and went from 16-18 mpg (conventional oil) to now, 19-22mpg (synthetic oil).
both people indicated the synthetic oil must create less drag on engine parts, thus their improvements and hence my idea of the synthetic oil creating less drag and helping the generator roll over easier and start easier.??..
Over the last couple months I have messed with this generator to try to get it to start better. Once winter set in, it wouldnt start. Changed spark plug, didnt help.
Finally took it to a guy, and he adjusted the valves. This morning, at zero degrees f, started on second pull. I never would have guess valve adj.
As for if the synthetic oil would help it start, roll over easier, I now dont believe so at all. Just figure I let ya all know. Thanks again for all rsponses.
namesray, do your own test. When I lived up north and temps were routinely below 0f my car started much easier with syn.
Get a cup of the same weight oil in both dino and syn. Put them in the freezer overnight. Then set both cups on a board or tray and tip them over at the same time. See which one runs to the bottom first. Simple test that will show which will flow through your cold engine the best.
Isn't 5w30 dyno oil the same viscosity as 5w30 synthetic? Its 5 viscosity when its cold and its 30 viscosity when its hot? So if the OP puts the exact same weight synthetic oil in instead of dyno oil, it will probably do nothing for cold weather starting, as it will be just as thick. It has nothing to do with the benefits of synthetic oil when it comes to wear and longevity, which is a completely different subject. Here's a good read on viscosity.... Motor Oil Viscosity Grades Explained in Layman's Terms
