t1-11 siding
   / t1-11 siding #21
Ditto that Eddie, also really no need to. I wash my vinyl sided house with 1/3 clorox and 2/3 water plus one-half cup dawn in a one gallon hand sprayer. Wet the surface, spray the siding bottom up, wait a few, then rinse down with hose. Stubborn stains I respray and brush with a vinyl siding brush on a pole extender.
Siding sparkles like new when done, do it every other year since I an surrounded by several large fields that generate lots of dust in dry weather.
Watched a guy pressure wash a house once, the homeowner took all kinds of water in the house and up under the moldings. Very few things needs that kind of pressure to be cleaned properly.
   / t1-11 siding #22
In CA we used stucco on our extra garage and tractor storage. I know it isn't good for snow areas ( it will absorb moisture and then freeze/crack) or in wet areas like Seattle as it will mold but in dry Southwest areas it works. They use 2x4 or 2x6, foam insulation, wire, a scratch coat, then a brown coat, and finally a top coat, then paint.
   / t1-11 siding
ended up using the pre primed wall board 4 by 8 sheets,comes grey in color,wnet up great and is sealed up good....I hope. Wont be applying paint for a few months. I will post some pics when we get closer
thanks
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
Heavy Duty Wheel Balancer Machine (A55852)
Heavy Duty Wheel...
2019 BOBCAT T450 SKID STEER (A52707)
2019 BOBCAT T450...
UNUSED FUTURE FT-X-DM43 43" HYD DISC MULCHER (A57193)
UNUSED FUTURE...
