t1-11 siding
   / t1-11 siding #21
Ditto that Eddie, also really no need to. I wash my vinyl sided house with 1/3 clorox and 2/3 water plus one-half cup dawn in a one gallon hand sprayer. Wet the surface, spray the siding bottom up, wait a few, then rinse down with hose. Stubborn stains I respray and brush with a vinyl siding brush on a pole extender.
Siding sparkles like new when done, do it every other year since I an surrounded by several large fields that generate lots of dust in dry weather.
Watched a guy pressure wash a house once, the homeowner took all kinds of water in the house and up under the moldings. Very few things needs that kind of pressure to be cleaned properly.
   / t1-11 siding #22
In CA we used stucco on our extra garage and tractor storage. I know it isn't good for snow areas ( it will absorb moisture and then freeze/crack) or in wet areas like Seattle as it will mold but in dry Southwest areas it works. They use 2x4 or 2x6, foam insulation, wire, a scratch coat, then a brown coat, and finally a top coat, then paint.
   / t1-11 siding
ended up using the pre primed wall board 4 by 8 sheets,comes grey in color,wnet up great and is sealed up good....I hope. Wont be applying paint for a few months. I will post some pics when we get closer
thanks
Deere 750K LGP (A53317)
Deere 750K LGP...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
UNUSED IRGC40 MINI ELECTRIC GOLFCART (A57193)
UNUSED IRGC40 MINI...
