Comparison T1054 Any Issues??
   / T1054 Any Issues?? #41
TYM does make tractors for Mahindra. The current models they make are the 26xx, 25xx series and the MForce and EMAX. They are built to Mahindra specs with a most with a Mahindra engine. I think the MForce uses the same Doosan engine TYM uses for the 105 hp tractor. Some have Mahindra loaders some TYM built loaders. The TYM built Mahindra’s are very popular.
If they use the Doosan engine then it's the same as the newer Kioti PX series.
They previously used Perkins but switched to Doosan a few years ago.
   / T1054 Any Issues?? #42
Hi TimberFarm
I only have about 400hrs on mine. I have a recent issue of the engine loosing its prime if it sets longer than a day. I haven’t been able to track down that issue. It will start right up and run for 7-10 seconds then die. Then it cranks over a few times and starts up and is fine. I can stop work for a few hours and it will start back up without issue. But if it sets longer than a day, it just losses it’s fuel prime. If I pump the prime bulb on the fuel filter until it’s primed, no issues.
My only other gripe is when all the fluids are hot and you are at 540 PTO rpm, there is a annoyingly loud harmonic that is eliminated 100 rpm up or down. It’s not a trouble noise but something in the PTO mechanics generates this frequency that is mind numbing when bush hogging. It’s been that way since day one. No worse and no better.
Other than that, I have no regrets. It’s a workhorse and we are very happy.
I just purchased the same tractor used.2019 version. So far so good. Have the same harmonic you are talking about.
As far as the fuel prime haven’t experienced it but the TYM dealer said to frequently “drain the water” out of the fuel filter sediment bowl. Says the tractor likes to accumulate h2o?
one major thing I am noticing is it has quite the lag time when shifting forward or reverse and it will lurch/jerk into gear. Don’t know if anyone else has that problem and if so how do you fix it? I know on my RX 7320 Kioti there was a feature where you could adjust speed for which it shifted forward or reverse with the power shifter but I’m not finding that feature on this tractor.
I also don’t have very smooth shifting on my range selector or in my gear speeds.
As far as features go I would definitely give it an A. The air conditioning system I would definitely give it an A+. Gets super cold. Hydraulics maybe a B. The detent hydraulic is very finicky. As for power probably a B+. Fuel efficiency and A+… Hi bailed 124 bales on less than a half a tank of gas on hilly terrain with the AC on. As far as the transmission goes I would definitely give it a D. Very jerky when going in forward or reverse with the power reverser/shifter. Very difficult gear shifter. Very difficult getting it into the different ranges from high/low/medium/creeper. Three point system probably a B-. There are lots of little sensors that control the position of the three-point since it is an electronic three-point system. If any of those sensors get knocked off or wires get disconnected the whole three point system will shut down. Also, the sensors that pick up whether you are going forward or reverse or making a sharp turn are very finicky so the “up when back” and “up with sharp turn” features don’t always work correctly….. but, when everything is working correctly the electronic three point system is amazing.
   / T1054 Any Issues?? #43
You didn't by any chance get that at auction within the past month+/-?
   / T1054 Any Issues?? #44
Yes….and no. I bought it a month ago from the guy who bought it at auction. Came from the Fort Smith , AR area and serviced at Bush Tractor. Picked it up in Perry,OK and brought it to TX.
The transmission issue is getting worse. Drained all the hydraulic fluid and changed the filters . Didn’t do anything. TYM says the tractor is still under power train warranty and recommends taking it to a TYM dealer. Problem is no local dealers. Nearest dealer that will work on this big boy is 3 hrs away. Uggg. What a Pain in the a$& !
I’ve called several TYM mechanics as well as Mahindra folks and everyone says something different. One says replace the hydraulic pump…other says replace the main hydraulic sub valve…the other says it’s a sub valve solenoid issue…another says it’s a clogged filter screen (btw…there ain’t no inline filter screen on the main hydraulics that I could find!)..another says it’s a bad clutch pack and needs a split! Don’t know what to do. Any advice is appreciated !
   / T1054 Any Issues?? #45
I put in a couple bids on that tractor. It was on AuctionTime.
The more I looked at the video, I saw the hard shift when the guy put in gear and decided to stop bidding.
   / T1054 Any Issues?? #46
On my 233, and the 273, the filter screen is a metal screen, in the transmission, filters The hydraulic fluid, before it enters the suction line to the pump.. To get at it, you have to pull off the left rear wheel.
Just follow the suction line back to the tranny, and you should find it, if there is one..
   / T1054 Any Issues?? #47
Nice eye! I didn’t pick that up! Honestly, I had driven another TYM 1104 as well as a Mahindra mForce and they were all difficult to shift so I figured “maybe that was normal “? My Workmaster 75 shifts like butter and has the power shifter. Unfortunately this tractor ain’t the same. But, to get a 3 year old 105hp cab tractor for $34k I figured it was a good gamble. Only using it to bale and cut and doing a little plowing so not too concerned.
   / T1054 Any Issues?? #48
I’ll have to see if mine is the same.
   / T1054 Any Issues?? #49
The more I think about this problem the more I’m leaning towards this being a problem with the solenoid accuated directional control valve situated on the main sub valve . Wondering if I removed the valve and cleaned it if that would help? Not sure what that process would look like though??? The valve controls the flow of hydraulic fluid which then pushes pins that then somehow moves the gears that places it in the forward position. Possible one of those pins is fouled up too?
   / T1054 Any Issues?? #50
Sounds like a complex project. You don’t know how often previous owners did things like fluid changes, or changed filters. And, if yours is hidden like mine, and a royal pain to get out and clean, they may have never done it.
I’d find the inlet filter and check it out first. It would account for the problem, and is one of the easiest things to remedy. First rule of trouble shooting is to look at teh easiest to do, and least expensive things to solve first.
When my Dad was in his decline, Mom’s Volvo started overheating, at least that is what the gauge said, and she ran out of gas a few times. I told Dad that there was a voltage regulator box behind the fuse panel. And, that if it went bad, it sent 12-volts to teh gauges, instead of 9-volts, and the gauges would read high. they went out frequently enough, and had been used by Volvo for a couple of decades at the time. I was near their place for a Doctors appointment so I swing by to say hi.
Dad had the radiator out of the car, and had dropped it off to be rodded out and rebuilt. I called Mom later in the week to see how things were going, and she said that Dad had the car back together, and it was still overheating. I told her that maybe it has an air block or something, and I’d come out that weekend and see if I could figure it out.
I went to the Volvo Dealer and bought the voltage regulator for under $20. I went out to their place on Sunday, arriving when they were at church, and put in the new relay. Then put a nice pork roast in the oven, and watched football until they got home.
After Lunch we went out and checked on Moms car. I burped the radiator hoses, and we took it for a test drive, and it didn’t overheat. I didn’t want to embarrass Dad, and tell him he wasted a couple hundred bucks. So, i never mentioned teh new regulator.
Lesson learned from Dad, Which he forgot as his age advanced, was to do teh simple stuff first. If you pull out the pre filter for the hydraulic system and it is in great shape, you have eliminated that problem. On T233, you have to drain teh hydraulic fluid, because the filter and pump inlet are at the low point, and all the fluid is coming out if you pull the filter. But you can catch the fluid if it is relatively new, and reuse it.
   / T1054 Any Issues?? #51
I don't know about a TYM but my Branson has a screen almost in the bottom of the transmission sump for the power shuttle.
Mine pulls out to the rear after undoing 2 bolts it's an oval housing on the rear down below the pto and to the right side. It also has a magnetic catch plug in the belly held in by two bolts. Neither of these are really mentioned in the owners manual.
Also I would expect that your tractor has a pair of wet clutch packs in it, one for forward and one for reverse.
   / T1054 Any Issues?? #52
There is no "pin pushing" to get a shuttle shift going.
The control valve puts pressure on the wet clutch packs to get the clutch engaged and tractor moving. It's two separate packs for forward or reverse.
   / T1054 Any Issues?? #53
Figured I would post what I know on this one even though it has been a month. The transmission is basically the same as a 903 or 1003 with all Service Bulletins applied. First, there is no screen before the main hydraulic filters. There is an inline filter on the line that feeds the transmission valve stack. If you trace back the line that goes into the top of the trans valve stack, front and next to the trans case, you will find something that looks like a long fitting. It can be removed, disassembled and cleaned. Second, the inching valve cable may need adjusting if it is being difficult to shift. May be the problem with the shuttle lurching too. Can be done without special tools but a pressure gauge is best to make sure it is engaging completely. Third, have the transmission pressures been checked? That was a major problem with the 903 and 1003. All came from the factory running low pressure and lost count on how many clutches we replaced due to that. It is adjustable by shimming the relief valve in the trans valve stack but there is nothing in the workshop manual detailing it. Did look up the trans valve stack and it is identical in this area on your 1054. That took a while to figure out, but once the pressure is turned up, that took care of the clutch problems on them. Feel free to DM me if any questions.
   / T1054 Any Issues?? #54
Sorry I never replied. After posting my response I dropped the tractor off at the dealer 2.5 hrs away. As I was pulling out from the dealer I received a phone call from my 14 y/o son that the house was on fire. Longest 3 hrs drive home ever!
When I got home the house was gone. Needless to say the tractor was the last thing on my mind! I did get the tractor back 6 weeks later. They said they replaced the main sub valve control unit ( part number: 18715162001 ). I got it home and drove it off the trailer and down and around in the pasture. Once it got hot it started doing the say thing!! So, after the house burning down because I wasn’t home when the fire started because I was dropping this piece of poo tractor off to get it fixed and then it wasn’t…..anyway, I digress. Long story short, I drove it right back up on the trailer and hauled to auction the next day!! Someone else’s problem now!!!
With that being said….I did recently pick up a smaller Branson 7845 that acts very similar. I’m going to drain all the oils and replace the filters and then start trouble shooting it. The hydraulic fluid looks a little milky so theirs probably some water that has gotten in. If fluid and filter change doesn’t solve the problem then I’ll be back here shortly asking for advice again!! At least there is a Branson dealer in Caddo Mills that seems knowledgeable and it’s only an hour a way!
   / T1054 Any Issues?? #55
So sorry for your troubles. Yes the dealer in Caddo Mills is great! Hopefully this Branson will serve you well.
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
2016 VERMEER PD10 PILE DRIVER (A60429)
2016 VERMEER PD10...
NEW Thiessen Track Closer Disk (A56438)
NEW Thiessen Track...
2023 John Deere 333G for Parts (A56438)
2023 John Deere...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
