Tach Cable, Before You Replace
   / Tach Cable, Before You Replace #1
troutsqueezer
Pilot Hill, CA.
Kubota B21
For anyone who is about to troubleshoot or replace your mechanical tachometer/hour meter cable, here is what I just went through. Searching TBN, I did not find much in the way of what to expect so thought I'd throw in my two cents for anyone doing a search on the subject.
My tach cable broke on my B21 last week so I ordered a new one through the local dealer. It was easy to install, just loosen the alternator, swing it down and unscrew the cable from the engine block. The other end involved removing the instrument panel and unscrewing that end as well. I put the new one on, buttoned everything up and started up the tractor. Still didn't work. Took it all apart again and sure enough, the new one had twisted in two. I thought maybe I didn't seat the U-shaped metal piece onto the pin in the engine well enough and somehow it malfunctioned so I brazed the cable back together and re-installed the cable - looking back, this was bad thinking on my part but hindsight is 20/20. This time I did not connect it to the tach and started the engine to make sure it was turning, which it was. I hooked it up to the tach and the darn thing still wouldn't work. Took it apart and the cable twisted in two again. It didn't break where my brazing was so at least I knew the joint was strong enough.
I removed the tachometer and dang if it wasn't frozen solid. After pricing out a replacement (too much $$) I stuck a screwdriver into the tach and forced it to turn whereupon it started to spin freely. I sprayed some WD40 into the sleeve which seemed to be where the binding was happening and it looks like that fixed it (for now). I took the broken cable and brazed it back together again. Fortunately, the wound steel the cable is made of allows brazing to take place. The tach readout is rock steady now which it wasn't before. We'll see how long it lasts.
So my advice, make sure your tach turns freely before installing a new cable, that could be why it broke in the first place. Just stick the square end of the cable into the tach and spin it with your fingers before installing.
   / Tach Cable, Before You Replace #2
Thank you! Always good to hear about tips & fixes. Several folks with the newer GC Massey tractors have had issue with their tachs; wonder if the tach is the real culprit and not the cable.… Mine has an older style, sounds exactly like yours. Nice to have a heads up! Merry Christmas! irvingj
   / Tach Cable, Before You Replace #3
Too weird. Just did the same thing (minus the cable brazing) on the tach for my JD 750.
Went wonky on me a couple of years ago, and I pulled it out intending to either have it fixed or replace it. It was gonna ruin $300 either way, so I just threw it up on the shelf and put an ammeter in the hole.
Got REALLY bored today and decided I couldn't break it any worse so I carefully pried the bezel off and started looking it over. Went to turn the input and it wouldn't move. Thought at first that the tool I was using (a square file) was too big but after some more investigation decided a little brute force might help.
Popped it loose and like you, squirted a little PB Blaster in the drive hole and cleaned all the old grease off the hourmeter drive. Relubed it and it appears to be fine.
Won't know for sure until I get a chance to reinstall it. With the heat houser on the tractor and needing to move the ammeter, that will be a major project so it probably won't happen until spring.
Note: A pair of parallel-jaw pliers does a nice job of re-crimping the bezel in place. I'll also put a small bead of RTV around it when I put it back in the dash.
2014 Grove TMS700E 60 Ton Hydraulic Truck Crane (A60460)
2014 Grove TMS700E...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
WATER TRAILER (A58214)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
