Tacky film on fan blades
   / Tacky film on fan blades #1
TomIre
College Grove, TN
Branson 3725
Did the 50 Hour Service on my 3725 and found something on the back of my fan blades. Not oily but more like tacky. A little bit was slung around the engine bay too. I cleaned it off and will keep an eye on it. Any idea what it could be it or where it can be coming from?
   / Tacky film on fan blades #2
Antifreeze can be a bit tacky when it drys.
   / Tacky film on fan blades #4
Mine is the same. Most likely bugs and vegetation residue.
Thought it could be bugs, etc as I do a bit of bush hogging. But, it's on the back side of the blades. Closest to the engine and "down wind" so to speak.
   / Tacky film on fan blades #7
That's the side that does the work. It's just bug juice mixed with a little dust & seed chaff.
   / Tacky film on fan blades #8
In one of the fields I mow with my riding lawn mower - the back side has quite a stand of milk weeds. Now - you want to talk about something that gets sticky. Just mow down a big patch of milk weed and let the sap dry.
   / Tacky film on fan blades #9
Yep. I usually wipe if off the blades and underhood body work after cutting season. I use window cleaner but I'm sure others would work fine.
   / Tacky film on fan blades #10
You can add Dallis grass seeds to that. Stick like a magnet to iron and easily stuck.
(12) ROLLS OF WELDING WIRE (A51247)
(12) ROLLS OF...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53472)
Hay Van FL-95 Bale...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
JOHN DEERE Z960M LOT IDENTIFIER 93 (A53084)
JOHN DEERE Z960M...
