Tail Wheel
/ Tail Wheel #2
Assume you mean on a moldboard or bottom plow. It keeps the plow running straight. With some bottom plows if you pull them off they will pull you in a curve (into the plowed area, normally to your right). Some of this will depend on how large the plows are and how heavy the tractor is and the ground also.
/ Tail Wheel
well my next question is do I really need it? It broke off . Do you think it would be a problem plowing without it . I have a 45hp tractor and it a 2 bottom plow with coulters. Its only going to be a couple of acres.
/ Tail Wheel #4
I don't think it will be a problem. TSC sells all those new plows without coulters or the tail wheel.
My neighbor has an old Ford plow and it has no tail wheel or coulters.
SKYJACK SJ86T TELESCOPIC BOOM LIFT (A62129)
SKYJACK SJ86T...
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
UNUSED JCT 84" HYD...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A61165)
2016 Volvo VNL...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
PROPANE TANK CAGE (A62131)
PROPANE TANK CAGE...
2019 International DuraStar 4300 Service Truck, VIN # 1HTMMMMN1KH714519 (A61165)
2019 International...
