Tankless LP Water Heater
   / Tankless LP Water Heater #11
Another plumber that wouldn't have one. All the above reasons. My concern also is that if it fails, I don't have a clue how to work on the controls. The last two I had anything to do with had to be sent back to the factory while under warranty. A long wait for hot water until it came back. I had my supplier finally admit that if a customer hired me to do the required clean and checks to maintain the warranty, it would actually cost more per gallon than a good electric.
I went to a class and became certified to install my own. Every single part in my tankless water heaters can be replaced. You can count on pitching your tank water heater completely every 15 years or so on average. I'd much rather replace a part than an entire system.
As I stated before; clean, maintain?? In 5 years I've not touched them. I 'cleaned' two of them only to find they had no need for cleaning. This is beginning to sound to me like the guys with horses and buggys talking about how terrible those motorized machines are. LOL
   / Tankless LP Water Heater #12
We also have a Rennai tankless heater. We have had it a little over a year and have been very happy with it. One feature I like about it is it is very easy to adjust the temperature. Sometimes when my back is bothering me I push the up botton on the control panel and turn it up to 115. After my shower I put it back on 110.
I don't understand the comment about waiting for the water to get hot. Our house is about 70 feet long with the water heater in one end and the master bath in the other. With the old tank heater I had to wait until the hot water pushed the cold out of the lines before the shower got hot. With the new one, same thing, I don't really think it takes any longer to get hot water to my shower. YMMV
The OP mentioned power outages. You need 110 even for a tankless, for the controls.
   / Tankless LP Water Heater #13
I wish everyone (except me) had 1. LOL... I charge good $$ to work on them. I've been to several classes on the Rheem unit
   / Tankless LP Water Heater #14
Everyone here that is posting probably has different types of water. So for some of us it may work fine and others who have hard water are going to have problems. My water is very hard. My gas 40 gallon waterheater needs to be cleaned out at least twice a year. It gets a very large deposit of calcium buildup inside of it. When it builds up it will sense a false water temp and fire up or maybe not fire up. Sometimes we have very, very hot water and sometimes it maybe just be luke warm water. A tankless water heater in my house would not work. It would be building up with deposits very quickly because the cores in these are much smaller than your standard 1/2" or 3/4" pipe. I would probably have to clean it out at least once a month to operate correctly. If you have soft water or a water conditioner it may be a good choice for you.
I've been a General Contractor of new homes for 41 years.
This is just my opinion
   / Tankless LP Water Heater #15
Gosh darn it, then you go to a class and learn!!
Well, being a Rheem, that was your first mistake LOL Sorry Ken, never a fan of Rheem on their separate hydronic side.
Thanks Brent, you've just given me a reason not to sell the brand you bought lol
There are other draw backs like, longer wait for hot water initially, you have to open the hot water faucet and leave it running, you can't let the water trickle, if you turn it on and off, you get cold, hot, cold, hot.
Ummm, and what water heater won't you have the problem with? Personally, if it's an extremely long run to the farthest outlet, I'd put a pump in with motion detector.
To the OP, being that you're on LP, it's a **** if you, **** if you don't trying to save money. As mentioned, because you have endless hot water, chances will increase that you will use more hot water than you have before, thus you will burn more gas.
As mentioned, the biggest issue on these units for people out in the "country" is the condition of the water. If you're on a well, almost a promise that you will need to clean the heat exchanger out at least once a year. A pain, but you vinegar usually does the trick.
Now, for what it's worth, I have a 75 gal LP direct vent sitting in the basement that has been there since the house was built in 1988, and I haven't changed it out yet LOL
Just make sure you look at the temp rise rating on the unit compared to the flow rate. Too many people go off of only the flow rate and end up getting in trouble.
   / Tankless LP Water Heater #16
They are difficult to work on. At Rheem we had them laid out on a table . They are difficult getting at some of the parts. In the class they give you a magnetic screwdriver so you can get to the small areas to hold the screws & small parts.
   / Tankless LP Water Heater #17
Interesting to read that those who are against them, don't own them.:confused3: I have had for the last five years an LP tankless unit and will report back soon-PROS AND CONS FROM AN OWNER-don't have time right now.
   / Tankless LP Water Heater #18
Even more amazing, I don't have to get too close to the edge of the roof, to find out I will fall off either. :D
   / Tankless LP Water Heater #19
I cannot comment on them. That is not the brand I have. The brand I have does start with the letter "R" though. ;)
   / Tankless LP Water Heater #20
Thanks Brent, you've just given me a reason not to sell the brand you bought lol.
It really is pretty easy, as I'm sure you know. I used my dad's HVAC card (okay, his name too) when I got (him) certified. Being that my dad honestly is only 15 years older than me, I didn't have too hard of a time. Yeah, now you know....I wasn't exactly the product of proper planning. :eek:
Oh yeah, I'm sure you also know, 180 degrees is waaaaaay too hot for a residential setting. Mine are the tan colored commercial units that are a little more BTU in size but don't stop at 120 degrees like the 1 residential unit I helped install. Oh, BTW, I do have 3 pieces of the really expensive intake/exhaust pipe someone over figured for a job though if you know anyone who needs any. If you know what I'm talking about, you know what I mean by "really" expensive!
We do NOT accept credit cards as payment. (A50120)
We do NOT accept...
John Deere 7430 (A50120)
John Deere 7430...
1986 East Tri Axle Semi Dump Trailer (NO TITLE) (A50774)
1986 East Tri Axle...
Swict Q.A 60" Bucket (A50121)
Swict Q.A 60"...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
