tc29 issue with rear wheels/hydro
   / tc29 issue with rear wheels/hydro #11
BE sure to check your tire pressure in those rears to be sure it's up to specs. I thought I had that problem, but it turned out that one of my tires was low, and the wheel was spinning, but the tire was not. From the seat I can see the tire, but not the wheel itself. Threw a bead and lost all my ballast. Cost plenty to get it refilled. I know. Dumb. But be sure about the tires...
This is likely it. From what I can see, there isn't a mechanism that allows a clutch to work the front, and not the back. Something is spinning on something somewhere, and this is the likely culprit.
Without a load, I can't tell my rear tires are flat(until I am on the side of a hill).
I have gone over everything and only thing I can find is mud packed in many areas that may have been causing diff lock not to fully engage. Has not done it since. One thing I did find is range selector input shaft on transmission is "loose" . It has alot of play in it and when in low range, I might not have had it completely in low range due to play in it. Not sure how to make this repair at all.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
(15) 1 RANCH 1RGPM GROUND PROTECTION MATS (A57193)
(15) 1 RANCH 1RGPM...
Takeuchi TL12R2 (A53317)
Takeuchi TL12R2...
2023 New Holland TS6.140 T4B MFWD Tractor (A53485)
2023 New Holland...
2020 John Deere 8245R MFWD Tractor (A53485)
2020 John Deere...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
