TC30 3-pont Linkage lubrication
   / TC30 3-pont Linkage lubrication #11
What I found works really well is a motorcycle chain lube called "Chain Wax". I get it at the Honda shop for my bike. It sprays on thin like WD40 and cuts/disolves rust. After a few minutes it sets up similar to a thin grease to act as a lubricant. Best part is it doesn't attract dirt like grease will.
Rodger
   / TC30 3-pont Linkage lubrication #12
I'll have to check out the "chain wax".
Is this the stuff maxima usa chain wax ?
The "fling resistance" will come in handy if I ever hot rod my tractor /forums/images/graemlins/tongue.gif
   / TC30 3-pont Linkage lubrication #13
</font><font color="blue" class="small">( My TC18 has no hand crank. The adjustable side is a turnbuckle. Requires owner supplied wrench. )</font>
Yikes! I wonder if that is a 'changed' item. Back in the late 98 or so.. I broke the adjustable link on my yanmar and went to the NH dealer to get one for a tc18. it matched in size great ( however the counter person actually would not sell it to me! as he said ti was ONLY for a tc18.. and not any other tractor ... how about that for an answer! It even had the correct sized ends on both sides. bummer. I ended up getting one from a massey and having a friend burn off one end and weld a 'replaceable' end on for me. )
Anyway.. I'm almost sure that unit had a crank then.. I could be mistaken though /forums/images/graemlins/shocked.gif as that was 7+ years ago..
Soundguy
   / TC30 3-pont Linkage lubrication #14
I'll have to check into it. After using Dad's deluxe TC40, I'd much rather have the hand crank. The adjustable lift arms are sweet too.
   / TC30 3-pont Linkage lubrication #15
Its the same for all the small chassis machines....no crank. Not sure when they dropped it but my almost 2yr old machine doesnt....
   / TC30 3-pont Linkage lubrication #16
I lube every thing with a zerk with a grease gun. Anything that moves including the threads of the leveling arm I spray with a can of white lithium grease. I just love that stuff the way it foams and gets in everywhere before the carrier evaporates and leaves the grease behind. I also spray all nuts and exposed threads on my equipment with it. Makes them easy to get off even years from now.BTW the dirt stays on the outer surface fo the grease and can be wiped of with a rag before taking it apart or to apply more.
Andy
   / TC30 3-pont Linkage lubrication #17
</font><font color="blue" class="small">( I'll have to check out the "chain wax".
The "fling resistance" will come in handy if I ever hot rod my tractor /forums/images/graemlins/tongue.gif )</font>
Yep, the same stuff. If you find any zerks on the 3ph let me know, I haven't found any.
I wonder if it's possible to upgrade to those fancy hand crank side links? Or is this the excuse I need to get a TnT setup. /forums/images/graemlins/grin.gif
   / TC30 3-pont Linkage lubrication #18
I might have to try that. I've been using Justice Brothers JB-80 on mine. That or LPS 3.
PALLET TOTE OF MISC CABINETS (A58374)
PALLET TOTE OF...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
LOLOT OF ROUND STOCK 2PC. (A58374)
LOLOT OF ROUND...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
WHEELBARROW & TOOLS (A58374)
WHEELBARROW &...
