TC33D temp. guage not working. Any idea's?
   / TC33D temp. guage not working. Any idea's? #31
Re: TC33D temp. guage not working. Any idea\'s?
</font><font color="blue" class="small">( My panel seems to fog whenever I wash the tractor off. The first time, the flasher indicators came on and flashed even though the switch was in the off position. I haven't put a whole lot of water on the dash since. )</font>
Rich, the flashing lights are the dashboard humidity sensor that just comes on the Dee-lux model tractor.
/forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
   / TC33D temp. guage not working. Any idea's? #32
   / TC33D temp. guage not working. Any idea's? #33
Jim I like that /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Rich the problem comes from dousing the relays with water. They are located beneath the instrument cluster and behind the two panels that you bang your knees on.
Once I found out myself what was causing the flashers to come on after a wash job I also found out that compressed air in the direction of the relays was the fix.
   / TC33D temp. guage not working. Any idea's? #34
   / TC33D temp. guage not working. Any idea's? #35
I spoke to soon, the last few days my temperature guage began acting up again and this afternoon it would only go to the first mark. In addition I have had the lights flash after washing the tractor. I like to keep the thing clean so I wash it and wax it as well. Hope that the UV doesn't get to the thing and so I clean and change things as the manual states but have had problems with the temp guage several times. Has anyone seen a recall on this problem?
   / TC33D temp. guage not working. Any idea's? #36
Check for loose relays.. or water trappe dint he holders.. spray out with a dispersing agent.
Soundguy
   / TC33D temp. guage not working. Any idea's? #37
Flashing lights is a common problem after washing a NH, don't ask me how I know that. I usually use compressed air to get the water out of the electrical after a wash job.
Your temperature gauge problem I believe was discussed in some detail some time ago. Do a search for temperature under the NH forum and you should find it. The fact that it is low indicates a problem in the cooling system to me. Bypass or thermostat related.
   / TC33D temp. guage not working. Any idea's? #38
Mike, how do you know? :D
Bob
   / TC33D temp. guage not working. Any idea's? #39
I received a reply from one of the members here and their suggestion was that moisture from condensation might be the cause of temp guage failure. I agree, on both instrument clusters I have had, there has been moisture under certain conditions. As to the flashing lights, I had to tighten the throttle cable nut on my TC33D, and the relays are right under the throttle, which means there is an open hole where water can go right down on top of the relays. Bottom line, maybe put a piece of electrical tape over the hole when washing the tractor. In addition I am going to take the panels off and blow the dust off that gets in there periodically.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRACTOR (A51243)
2012 MACK PINNACLE...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
