TC33D wont start, no lights. Main fuse where?
   / TC33D wont start, no lights. Main fuse where? #1
Anonymous Poster
Epic Contributor
I get nothing when i turn the key. Its not the stating fuse because i have a breaker in its place and i did replace with a fuse to be sure. I checked all fuses in the fuse box all good. Is there a main fuse and if so, where? Not the battery because is was running fine all day and i stopped just for a second and then it wouldnt start. Help!!!
The main fuse is on the other side of the tractor. Mine is attached, or very close to the starter. I think the owners manual shows it on the fire wall by the starter. Good luck..
   / TC33D wont start, no lights. Main fuse where? #3
One of your neutral safety switches may have also come out of adjustment which would not allow the starting circuit to complete the most common one to malfuntion is on the shift lever. The safety switch in the seat has also been known to cause some grief!
   / TC33D wont start, no lights. Main fuse where? #4
It was the main fuse. I found and replaced. Also first post since i got crashed on this forum and am starting over.
Mike
   / TC33D wont start, no lights. Main fuse where? #5
Mike
Hey Mike,
Where was the 'main fuse' located, as we have the same issue? No lights, etc.
   / TC33D wont start, no lights. Main fuse where? #6
See below:
   / TC33D wont start, no lights. Main fuse where? #7
It was the main fuse(30 amp)...thx for the help/diagram!!
   / TC33D wont start, no lights. Main fuse where? #8
Do you know why it blew?
   / TC33D wont start, no lights. Main fuse where? #9
nope
   / TC33D wont start, no lights. Main fuse where? #10
Don't panic they haye a history of just blowing for no good reason if it does it again then it's time to start investigating. Just check the obvious first like the battery terminals and leads. A good PM never hurts.🍻
flatbed trailer 24ft (A56857)
flatbed trailer...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
