TC35D Tranny Cooler Leak
   / TC35D Tranny Cooler Leak #11
...either way i'll probably be ordering a new one from messicks as they are $40 cheeper than my local New Holland dealer.
Does $40 cheaper include shipping?
   / TC35D Tranny Cooler Leak #12
I had remembered a long thread that talked about this problem:
hydro cooler failure TC40D
Thank you Chris! I looked and looked for that thread and didn't find it because I thought it was an older thread and just ignored it when it came up in the search. :rolleyes: That thread has all the cooler configurations in photos even if we did ramble on a bit in the middle of the thread. Lots of good info there.:)
   / TC35D Tranny Cooler Leak #13
I had a file with all the main problems that the Class III tractors had, and the threads that I considered to contain the definitive descriptions and solutions. Then the forum format changed a few years ago and none of the links worked - oh well!
   / TC35D Tranny Cooler Leak #14
My TC35D just turned 1000 hrs, had to buy oil cooler in 2008 and now another. Local NH dealer wanted $331+tax; found it for $222 including tax and shipping at Superior Cooling Systems.... there were several online sources starting at $179+ if you google the oil cooler part # 87301196. Pinching every penny these days!
   / TC35D Tranny Cooler Leak #15
I think it's sad that you had to buy the 1st cooler, much less the 2nd.:mad: I'm thankful that my older TC45D has the more rugged cooler before the newer models changed. It's a real case of penny-wise and pound-foolish in the later tractors. I hope this new cooler is a permanent solution for you.
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2016 Ford E-450 Passenger Bus (A56858)
2016 Ford E-450...
