Techniques to picking up gravel w/ FEL ?
   / Techniques to picking up gravel w/ FEL ? #11
bcarwell,
all of the actual advice, above is what I've had success on---without a toothbar. One other thing I learned here in the hallowed halls of TBN, is to use your FEL to backdrag the material off the top of the pile a few times, then slowly advance and curl at the bottom, to the top. Remember to back drag off the top, first, if the pile is not cooperating.
v/r mark
   / Techniques to picking up gravel w/ FEL ? #12
Houndsman said:
bcarwell,
v/r mark
We have a winner! You do not need a teeth to load gravel.
As Houndsman said, backdrag the top of the pile, this does two things: 1. It allows you to attack loose material that will flow into the bucket; 2. it allows you to use the back of the pile to "push" the gravel into the bucket. Keep pulling the top of the pile down, and you'll have an eaiser time, even if you turn it into a 2 foot tall windrow instead of a pile.
There are several ways to attack the pile. One person mentioned setting the blade of the bucket on a cutting angle, then curling and lifting your bucket. This works pretty good, if you are careful not to dig huge holes in front of, and under the pile. If that happens, it just slows down loading, and gets lots of dirt in the rock. If you use this method the cutting edge of the bucket should just skim over the ground, not dig in. If it is digging in, lighten up on the controls. Once you master this technique you can pick up dirt, sand, whatever on pavement without tearing up the pavement, and without spreading the material all over the road. A tip for this technique is that most loader buckets have a little play in them, esp if they are not brand new. You'll know you have enough downward pressure on the bucket with you see that play load down, but not gouge the ground/pavement.
If you are pulling the top of the pile down, then you can just level your bucket, lower it to the ground and drive into the pile. Don't crash into the pile, and then try to load the bucket. Make the tractor's speed and power work together. Don't raise your front wheels off the ground, esp if you have fwd. If you are just learning, slow down. As your bucket slides into the pile, and as (or maybe just before) you feel/hear the engine start to load up, slightly curl the bucket while lifting it. Driving into the pile, curling the bucket and lifting the loader should be all one smooth motion. Think of the cutting edge of the bucket as a knife. You want to take smooth slices, not try to gouge a hunk out. Once you master the motions, you can speed up and loading the bucket will become eaiser. If you are doing it right it should be possible to have a mounding load of gravel, or to even have gravel coming over the top of the bucket as you load it.
After you load the bucket, if you are moving the gravel with the tractor, then lower the bucket and take off. If you are loading trucks, then turn as you are backing up from the pile, and as you go forward raise the bucket to clear the truck.
While I agree having enough weight on the tractor is important, proper technique is probably just as important. If you spend very much time on construction sites you will see people on backhoes and loaders with way more weight than your machine spinning their tires because they are "drivers" not operators. Learn to be an operator. You've invested lots of good money on a good machine, but to get the most out of it, you have to invest time and attention to build the skills. I guess this is true for about anything, sports, arts, other trades. This forum is a good place to start, but some of it can only be learned from the seat. (which is fun anyway :D )
   / Techniques to picking up gravel w/ FEL ? #13
Houndsman said:
bcarwell,
v/r mark
I've used that trick at times depending on the situation.
   / Techniques to picking up gravel w/ FEL ? #14
It's been pretty well discussed at this point, but the main trick is coordinating 3 motions -- forward slowly, lift and curl the bucket. Use low range or low gear. Use 4 wheel drive if you have it. Keep the rpm up to make sure the hydraulics are working their best.
If you get one of the 3 motions out of synch with the other two you will either simply stop or get just a little gravel in the bucket. Ideally, your forward speed and lift/curl will keep the cutting edge just a few inches below the surface of the pile as the bucket goes forward and up. Practice, practice, practice. If you go forward too fast, you'll probably stall out the engine or the hydraulics. If you lift too fast you won't get much gravel. If you curl too fast you will be trying to bulldoze the pile and won't get anything but a dent in the pile. You will probably be pretty good at this little skill when you have the first pile about done. For the stuff you spread out, just set your bucket flat and on the ground and drive forward over it. You will be surprized how much you can pick up.
I had a driveway overfilled with gravel about 2 years ago. I could drive up the curving drive with the bucket down and get about half a load. Then raise a little, curl it back so the gravel went to the back, drive up again with the bucket down, and I could get very close to a full bucket of #57 limestone. This was uphill, which helped a lot, and the gravel was pretty deep and loose.
I have about 900 lb on the hitch plus 130 lb on each rear wheel of a DX29
   / Techniques to picking up gravel w/ FEL ? #15
1* Tutored my wife on operating the BX23 FEL.
She didn't do bad for a first timer.
Kinda slow but still faster than a shovel. Can't brag on her though cause it don't take to much to beat a shovel .LOL
Told her I was glad I wasn't paying her $40 an hour for moving dirt.
   / Techniques to picking up gravel w/ FEL ? #16
No toothbar needed here either ... but I've only moved ~15 tons of gravel so far. Using JerryG's method, I can have as little as 5' rear blade on for ballast.
   / Techniques to picking up gravel w/ FEL ? #17
I had a B7500 that moved lots of gravel with no toothbar. It had filled tires and the 48" KK BB on the back.
It is just a matter of a constant push-lift-curl...simple:)
   / Techniques to picking up gravel w/ FEL ? #19
Yup, seat time. Skill is developed over time, with patience and attention. The techniques presented here helped me move over 120 tons of dirt, sand, gravel and babyheads over the past year . . . no tooth bar and only a 4' box blade in the rear. More rear weight made the transporting the load from location to location smoother but I was certainly able to fill my FEL bucket to capacity and lift it to its max height with the ballast that I had.
I started with the jousting charge technique . . . until I actually read the FEL operators manual . . . which I did not get with the tractor and had to download. Sure that worked to get material in the bucket but efficiency was zilch and it seem to be a lot of work for me as well as the tractor, not to mention it is not good for the tractor. Eventually, after a few hours of quality seat time, I got the hang of it. The first time you do it right you will know it and you will begin to learn what it feels like . . . muscle memory will develop and eventualy you do it without thinking.
Practice, practice practice. This is one activity I can't get enough of and look forward to every opportunity I have to work on skill development.
   / Techniques to picking up gravel w/ FEL ? #20
My gravel scooping technique requires much skill and finesse. I only put gravel I am going to use later on a gravel pad against a tough excavated bank (same for the mulch pile). Scoop and go. Always pile your stuff where you can easily get at it with the tractor later.
Steve
MACK DUMP TRUCK (A59823)
MACK DUMP TRUCK...
BROCE BW260 SWEEPER (A60429)
BROCE BW260...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
TANK MANIFOLD (A55745)
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
