telephone pole question
   / telephone pole question #31
KennyD,
Are the "green" poles treated with the same chemical as treated lumber?
Don't know...I just climbed them-not treated them:D
I suspect not though, especially since most regular treated lumber is not rated for ground contact, whereas the poles obviously are.
   / telephone pole question #32
Poles in OZ are treated with CCA (Copper Chromium Arsenate) . They are pretty safe unless they are burnt , the ashes will kill cattle if they lick them . Splinters in your skin will get infected , and it is a no no to build horse yards with them as the horses chew the tops and can die . But used for it's intended purpose of protecting poles , it does very well .
   / telephone pole question #33
You don't want to breathe the saw dust when cutting them. Also, they're not approved for indoors due to fumes during a fire.
   / telephone pole question #34
I was wondering what you guy's familiar with tel. poles thought about using ,say, 2" cut boards for a vehicle bridge top? versus the cost and added weight of concrete.
most bandsaw guys wont do it for 2 reasons.
one breathing the dust is WAY toxic (worse than regular pressure treated material) two, you get about 1 cut per blade so if you do find someone to do it expect them to charge an addtional fee to resharpen all the blades they go through.
   / telephone pole question #35
Roger that , I had Asthma like symptoms for two years after I built my pole frame home out of them . Even though I was wearing a twin filter dust mask , it still got in . I could still taste it on my lips the following day after cutting it . Arsenic is an accumulative poison , it wont kill you straight away , but when the level reaches a certain amount...............
I was doing some pretty serious cutting of them though , I was chainsaw cutting grooves 10' long by 1 1/4" wide and 3" deep to house the solid walling I used .
If I suddenly stop posting one day , you will know what happened .:D
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2015 FREIGHTLINER...
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
2020 KUBOTA RTV...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
