Telescoping Draft Links
   / Telescoping Draft Links #11
Thcri,
<font color="blue"> I even swapped them out and she still finds the <font color="green"> green </font> one and the <font color="orange">orange </font> one she leaves alone.
</font>
Can't help but thinking she may be trying to say something! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Then again, I'm a <font color="orange"> Kubota Owner </font> /forums/images/graemlins/blush.gif
   / Telescoping Draft Links #12
</font><font color="blue" class="small">(
</font>
Then again, I'm a <font color="orange"> Kubota Owner </font> /forums/images/graemlins/blush.gif )</font>
She is dead if she touches the black tires on the blue machine!!!
Murph
   / Telescoping Draft Links #13
<font color="blue"> She is dead if she touches the black tires on the blue machine!!!</font>
Luck she got the right gender...otherwise she might just lift her leg! /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
Just joking, naturally... /forums/images/graemlins/blush.gif
   / Telescoping Draft Links #14
</font><font color="blue" class="small">( ... she still finds the green one and the orange one she leaves alone. )</font>
Murph, if you are talking about the l.e.d. lights then have you tried covering them up with electrical tape?
   / Telescoping Draft Links #15
Spence,
Not only have I taped them up, I have made a sheet metal box around them just leaving the eye open and she still was able to chew on the wire until she pulled it out of the eye. I dropped a piece of conduit down over it and supported it and now she can't get to it. The thing I was saying, she would never chew the orange light only the green one. So I have no green but all kinds of oranges around because you can only get them in a kit.
Murph
   / Telescoping Draft Links #16
I have actually bent one or 2 /forums/images/graemlins/crazy.gif. darn tractor has more power than I thought..... /forums/images/graemlins/shocked.gif
   / Telescoping Draft Links #17
I bought my JD 5220 used and it did not have the extending links ... When I priced them at the dealer ( I looked at the price list myself) they were over $400.00 each! So I got an I-match ... so far this has worked great ... If I where you I would order the extending links as I think they are all you need and you do need something ... if your back is like mine ... it gets tired of trying to hook some of these very heavy implements that wieght over a 1000 lbs ...
Leo
   / Telescoping Draft Links #18
Is there any concern or thoughts about the telescoping links possibly being weaker than the standard links? In either draft or lifting movements - or maybe even worse (?) in compression when using a back blade in reverse?.
The telescoping links on the 5x20 series look a LOT beefier than the available photos of the CUT versions.
</font><font color="blue" class="small">( I have actually bent one or 2 )</font>
Are you referring to telescoping links?
Do they seem prone to problems?
   / Telescoping Draft Links #20
Tim....
<font color="blue">"...any concern or thoughts about the telescoping links possibly being weaker than the standard links?..."</font>
In my opinion.....NO. these telescoping links on my 4710 look to be very durable. They extend out about 5-6 inches. The extended portions appear to be very durable and well made just like the main part of the link. I've not had any problems with the telescoping links and at this point haven't had any concerns about potential failure under heavy loads.
...Bob
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
TRANSMISSION JACK & FLOOR JACK (A53843)
TRANSMISSION JACK...
SET OF (4) NEW 11R24.5 TIRES (A53843)
SET OF (4) NEW...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
