Tell me if I'm on the right track (newbie)
   / Tell me if I'm on the right track (newbie)
Maybe Canadian prices?
Possible, with the tariffs the U.S. has imposed on China and Canada in the past year - and Canada's retaliation - it's distinctly possible prices end up very different, if say the Branson is first imported into the U.S. while the Kubota comes direct from Asia.
I like my Branson but based on features I'd get an L60 if it's the same price. Some people may be concerned about the electronics and regen on the Kubota.
Curious what's your reasoning? Mind you, I haven't sat in either machine yet, but on most specs the 4225H and L4060 are very close, with the Branson significantly higher on loader capacity. Mind you, I certainly see a lot more orange than red around here, so a) I wonder why, and b) probably eventual resale of the Kubota would be easier.
   / Tell me if I'm on the right track (newbie) #52
Given the preceived "quality" and "value" of the orange over pretty much everything else CUT/SCUT, I'd've gone orange instead of red if the price and features were equal.
In my case, I got a significantly heavier tractor that could lift twice as much for about the same price (3520h w/ FEL & Backhoe vs same on L3301). My dealer is much farther away (2 hours vs 15 minutes), but I'm handy and willing to learn more and confident that my dealer has parts availability. There's a lot going into the decision - features/capability, financial, warranty, dealer, location; there can't be a right answer for everyone, but there's plenty of anecdotes for free here (just have to view the occasional ad haha).
Also: Resale value is a red herring unless the purchase price is very similar or the resale prices are hugely different, as there's a cost for tying up the money today for a return tomorrow instead of putting it to better use now.
   / Tell me if I'm on the right track (newbie) #53
The HST+ additional automatic two speed transmission on the L60 would be the biggest one. I have to stop to change ranges on the Branson (that's typical on CUTS as there's no synchros on the range transmission). Being able to slip between the two gears while moving extends the range of each range. In my case I'd be able to go faster on those short transfers between work areas (my land is steep; there's no place where I need high range). Other parts of HST+ sound interesting but some like stall guard I don't see much need for myself. I've not stalled the Branson, I can hear when the engine's dragging down and I let off the HST pedal.
Branson's mechanical linked HST and throttle works well in low and mid range but in high range I need to add throttle. An electronic system like Kubota's would know what range it was in and adjust accordingly. OTOH there's no regens needed on the Branson and if I have problems with the DPF (I haven't) I can remove it. With the Kubota there's regens though from what people post they're pretty painless.
There's a good video by Messicks' about the HST+. Messicks' videos are useful even if you don't have a Kubota.
Kubota rates their loaders lift at some distance from the pins while everyone else rates them at the pins. So their rating looks lower than it is. I'd have to make measurements and do math to see how much difference it really is.
Don't get me wrong, I like my Branson a lot. It'd have been $10k more to go to the similar HP L60 Kubota. HST+ sounds nice but it's not $10k nice. And my Branson dealer's much better than the two Kubota dealers I visited. OTOH I've gotten so much more use out of the tractor than I (or my wife) thought that I could have justified that $10k had I known. She said as much after a year of owning the Branson. I'll hold that thought for when it's time to get a backhoe.
The 4225 and 3725 are the same except for the fuel injectors (per my dealer). The 3725's engine is super smooth and quiet. Much more so than an L3301. I think the balance shaft is why it's smooth.
Kubota resale would probably be easier where I am because Kubota is more well known. I don't plan on selling it though so that was not much of a factor.
   / Tell me if I'm on the right track (newbie) #54
houska;5332666.......... on most specs the 4225H and L4060 are very close said:
I thought we found earlier that the Branson rated higher on loader capacity because of the way the different companies measured their FEL lift. As I recall, when measured the same way both brands came out very nearly the same. Typical advertising fluff.
rScotty
   / Tell me if I'm on the right track (newbie) #55
rScotty
Looking at specs directly (Kubota, Branson BL25R, Branson BL200), I see:
Max lift height: 104.7" 103.8" 104"
Lift @ pins: 1715# 2100# 2701# (Branson doesn't state it's at the pins on the BL25R, but it probably is)
Breakout @ pins: 3301# 3531# 3660#
I don't think it's a matter of "measuring it differently" here; the Branson loaders are - at least on paper - definitely stronger.
My tractor - 3520h - has the BL25R and I was using it to compare when I was buying - remember that at my price point, I was comparing to the L3301 which was actually more expensive than the Branson setup; the L3301 had the considerably weaker LA525 (1130# at the pins @ full height). I believe Eric's 3725h has the BL200, which is even stronger yet.
   / Tell me if I'm on the right track (newbie) #56
Yeppers, that's my point. It's easy to manipulate loader specs and tractor manufacturers have been doing it for a long time. I can remember law suits on those very specs back in the 1970s when we first began to see foreign built compact tractors. And the advertising departments act like it's all new again.
For instance, take the "breakout force" you mentioned. Just what is "breakout force". Does it include bucket rotation? Or just loader arm lift? Or both of those things taken together? Or both in sequence? And where is it measured? Every manufacturer has their own definition and opinion. Pretty obviously the one place it is meaningless to measure breakout is back at the bucket pins. I'm not sure that most definitions of breakout force even exists at the bucket pins. Lift maybe exists there, but breakout force....well, probably not. The best place for that would be out at the far lip of the bucket, because that is where resistance to all the above is max.
If we measure breakout at the pins do we even need have a bucket on the FEL? Now there's a pretty nifty question. The engineering and advertising departments might have different answers for that one. As well as buyers versus salemen.
BTW, lift specs without giving the height at which they are measured are also meaningless. The way FEL geometry works on tractor loaders means that it doesn't lift nearly so much at full height as it does down low. It's not a matter of stability, it's a matter of geometry. So load is not typically a number, it is a usually shown on a chart of height vs lift force. And when you look at the chart, note that not only is the lift force different at the pins versus in the bucket, but it isn't even the same shape of lift curve.
So we need to be comparing lift using those those charts of force versus height. THere's a page of those charts n my Kubota and John Deere manuals. Normally there will be a series of curves on the chart showing lift force vs height taken at the pins and also at other points in the bucket and at the far edge. That way compares forces rather than advertising skill.
rScotty
   / Tell me if I'm on the right track (newbie) #57
If your road is currently accessible in 2WD, it cannot be that bad. Give some serious thought at just how "good" a road you want vs what you need. That will dictate how much tractor you need.
Is it practical to move your camp/cabin site so that a 2.5 mile road for cars is not needed? If you could set up 200-400 yards into your property, it makes rest of your road part of your ATV trails.
   / Tell me if I'm on the right track (newbie) #58
Mine's a BL25, the 200 came out a while after I got my 3725. I looked up the specs for Kubota (on the USA web site) and they now list capacity at max lift both at the pins and at their traditional 500mm in front of the pins. The LA855 does look like it has lower capacity than the Branson loaders. There's also a smaller and larger capacity loaders for the L60s. I don't know which models can take which loaders.
The Branson does have two HST+ features- linked HST and throttle and cruise control. On the Branson cruise is an electromagnet that holds the HST pedal in place.
   / Tell me if I'm on the right track (newbie) #59
I believe you should be able to maintain the ATV trails with a chainsaw, bush axe and a 4wd ATV. I would be more concerned about maintaining the road and getting the right piece of equipment for that purpose. In my mind a good access road into a property of that size is way more important than the ATV trails.
I am also in the same camp about getting a good used industrial piece of equipment to maintain the road, especially if you need to work in the ditches and on culverts. Once you get all the heavy work done you can always sell the industrial equipment and purchase a tractor for regular maintenance or keep it and buy a good used tractor to go along with it. I have several friends that own 100 plus acres of land. Almost all of them have an older dedicated back-hoe, dozer or an industrial size tractor for big jobs that pop up coupled with an older 2wd farm tractor for regular maintenance (bush hogging, grading, tilling, etc.).
I believe you will eventually come to the right conclusion and any type of tractor or piece of equipment you choose is going to make your life better and easier. Enjoy that property. Lots of folks would love to have several hundred acres to play on.
Well, we have pulled the trigger on a Branson 4225h with loader, backhoe, and grapple. To be delivered in April. Thanks for all the advice in this thread.
Both the Branson and a Kubota L4060 would have fit the bill, and -- in our neck of the woods -- were priced similarly. The Branson led on specs that mattered, but even more important was dealer.
The Branson dealer is en route between our home and the property we'll use the tractor on. Knowledgeable guy, 20 years selling Bransons, repair shop where techs get their hands dirty really fixing stuff. Was much happier showing me what custom mods they had figured out for a disabled fellow to be able to use a backhoe that going over paperwork in his messy office. Together with the "do things mechanically" philosophy of the Branson design, this inspired confidence for the long term. Kubota dealer also good guy, long-term dealer, but his gleaming glass-wall dealership is an hour in the wrong direction, and philosophy is much more "when there's a problem, we'll swap out the electronics with a replacement so you're quickly on your way". That's convenient when you're under warranty, but smells of $$ afterwards and who knows what happens when your model is 10 years old. The Branson dealer did a better job explaining to me what's special about Kubota's HST+ than the Kubota dealer, who pointed me at their marketing material for "details" since he clearly didn't know. Bottom line at Kubota was "we're the market leader so we're clearly good, we don't need to sell too much".
Kioti and LS had tractors which weren't bad, but seemed (on paper) less a good fit. Their dealers struck out their at bats by not having the appropriate models in stock to see and touch, and more importantly by bad selling. The Kioti dealer decided within 5 minutes his "best selling tractor" (even if he didn't have any in stock...) was the answer for me, and was utterly impervious to gentle prods that I had (based on suggestions here, in part) been thinking of something quite different. The LS dealer offered a good price, but tried selling by putting down other brands with information I knew from my research was factually incorrect. Since both dealers weren't conveniently located either, really no reason to keep them in the mix.
Looking forward to doing stuff in the spring!
(By the way, I appreciated all the feedback above also on what to do myself vs outsource, tractor vs ATV vs miniex etc. I didn't reply to all of it directly, and some of it just reflected differences how people interpreted my description of our needs. But it all helped in our thinking, including just helping us become clearer on what we do and don't want to do right off the bat!)
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
CENTRAL PNEUMATIC SAND BLAST POT (A52708)
CENTRAL PNEUMATIC...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A56435)
Mahindra 4550-4L...
