Texas Fall/Winter thread!
   / Texas Fall/Winter thread! #4,652
Dennis my wife,, Betty,, they have her on 9 prescriptions right now.. but the aspirin is 325 mg per day,, plus another blood thinner,, Hopefully on 5th of Feb. she will be taken off some of the stuff,, mainly the Zoll life vest defibrillator,, she has to wear it all the time,, less bathing,, it monitors her heart beat,, plus send all this information to some doctor in where every.. it will call 911 in case it is needed and give a location where she at for the EMT.. So I can feel your uncertainty of what's next.. sounds like you have a large family just like we do.. So lean on each other till things are better,, but keep us informed when you can,, and good luck.. Lou
   / Texas Fall/Winter thread! #4,653
Jim I was interested in joining till I saw you were targeting the Canadian hosers,, Those Red Green people buy anything,, Lou
ps,, hosers - howers, tomatoes - tamales,, tacos,, ju no.. Lou again..
   / Texas Fall/Winter thread! #4,654
True story,, As I had mention earlier I decided to bale a few round bales from an over grown dead field,, sure enough one of my neighbor came over while I was baling,, Larry,, His words.. What do you think you are doing?.. My words.. And we all thought you were the smart one.. He shook his head walked over to the truck got a beer and waited till I got thru.. Then I had to explain the new driving range.. They shut down the local driving range so they could build some sort of Mall with parking.. Dank what next,, new homes and apartments? Lou
   / Texas Fall/Winter thread! #4,655
Lots of different blood thinners.
Coumadin/warfarin are common and can be measured for getting too much or not enough.
Heparin is substituted before surgery because its effect can be reversed very quickly.
Plavix, which my mother took, along with a 325 MG coated aspirin can not be measured but works good.
After 3-4 years her skin could be bruised with little pressure though.
They all have good points and bad.
   / Texas Fall/Winter thread! #4,656
Brandi, hope you feel better soon, stomach issues are sure a PITA. Could be worse I suppose, read an article that a woman was killed in Willis! Was trying to pull a tree with a traactor and it flipped over and killed her! Willis woman dies in fatal tractor accident - Your Houston News: News
Thanks Y'all. Stomach still churning. Bilnoski Road is not far from me. Only way I pull a tree is with the hi lift bumper jack and chains after some BH digging around the roots. This way is really slow motion when the tree starts going down.
hugs, Brandi
   / Texas Fall/Winter thread! #4,657
Me, I fill the FEL, put it in FWD and hook the chain down low on the drawbar.
With good physics, it is very difficult to flip a tractor.
   / Texas Fall/Winter thread! #4,658
If downward force behind rear axel exceeds downward force in front of rear axel, guess what happens? It's physics.
This is case where rear tire loading has zero effect. You need to offset rear 3 point weight with sufficient front weight like ballast in FEL or actual front weights.
   / Texas Fall/Winter thread! #4,659
Ron Coumadin was what she was on when she lost her leg.. it causes blood clogs,, and did.. reason she has one leg.. She is on Plavix and 325 mg aspirin now.. hopefully everything will work out for a few more years.. She's the one that works out every day at the gym,, till this,, but she will be back,, she a fighter,, watched her diet,, lots of veg's, little salt and no sugars, very little red meat and no alcohol unless we were in vegas.. I am just now aloud to say what I think,, they broke her ribs with the CPR and when I made her laugh it hurt but the ribs are better and she laughing now.. So we will go from there.. thanks for the info,, Lou
   / Texas Fall/Winter thread! #4,660
If downward force behind rear axel exceeds downward force in front of rear axel, guess what happens? It's physics. This is case where rear tire loading has zero effect. You need to offset rear 3 point weight with sufficient front weight like ballast in FEL or actual front weights.
Pulling a big load is also not same as a straight lift with your 3-point.
2015 Nissan Pathfinder SUV (A56859)
2015 Nissan...
UNUSED Wheeled Dump Hopper (A55272)
UNUSED Wheeled...
2026 Anvil AT7X15TA2 16ft T/A Enclosed Trailer (A56859)
2026 Anvil...
2014 Jeep Grand Cherokee SUV (A56859)
2014 Jeep Grand...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
24 BIG TEX GOOSENECK TRAILER (A58216)
24 BIG TEX...
